Vag Logs from mapped Cupra R
Chaz
Here is a log (115) from a mapped Cupra R. This isn't my car and I drive a Leon Cupra, I am not sure what the boost levels are suppose to be at. Does it look ok?
Code:
Group A:	'115
RPM	Load	Absolute Pres.	Absolute Pres.
 /min	%	 mbar	 mbar
2520	118.8	1990	1570
2680	123.3	1960	1630
2880	124.1	1940	1620
3040	127.8	1920	1610
3240	130.1	1910	1660
480	133.1	1900	1680
3680	130.8	1880	1680
3840	130.1	1870	1650
4000	130.1	1880	1640
4200	133.1	1860	1670
4360	136.8	1850	1680
4560	139.8	1830	1700
4720	141.4	1820	1710
4920	143.6	1790	1710
5080	142.9	1800	1730
5240	141.4	1820	1710
5400	137.6	1830	1710
Dan Cupra R
The Yellow Sub
May 2, 2006
1,514
Reading
It was mapped by Will @ P-Torque in a group buy on SCN back in November from here http://www.seatcupra.net/forums/showthread.php?t=101015
However, when it was rolling roaded it made 179.2 BHP & 191lb/ft.
the guy from JKM said the car was losing between 20-30bhp due to it running rich, Which would suggest sort out the rich running & the car should be about 200BHP suggesting that the map works?
Ive got the RR print outs as well if u want a look?
acidstrato
My Fast says shut up!
Dec 9, 2004
5,942
Newport, South Wales
titles are not important, requested is the left, actual is the right,
defo not a healthy bunny, take it these are dans
would say dodgy leak, dodgy n75 or dodgy map...is this another ptorque map? who was the other guy with a ptorque map that was having problems? be good to compare the requested boost levels
acidstrato
Dec 9, 2004
5,942
the problem is air fuel ratios are calculated by the ecu from the values it gets from the engine sensors, therefore the ecu should automatically adjust the fuelling itself, rather than older cars where you would have to adjust this manually
things like lambda sensors and maf can cause dodgy air fuel ratios or a dodgy map
but that log tells you its not boosting good anyway
Chaz
here is the MAF log as well.. I think it looks ok...
Code:
'101
RPM	Load	Inj. On Time	Mass Flow
 /min	%	 ms	 g/s
3360	130.8	17.22	84.36
3680	129.3	17.22	91.61
3840	130.1	17.22	95.92
4040	128.6	16.81	98.11
4200	133.1	18.04	108.39
4360	135.3	18.45	113.97
4520	138.3	19.27	120.56
4720	139.8	19.68	127.06
4880	142.1	20.5	131.03
5080	142.1	21.32	138.31
5240	139.8	21.32	138.75
5360	136.8	20.91	139.64
5520	134.6	20.91	140.44
5640	133.1	20.91	143.36
5760	133.8	20.91	148.17
5880	132.3	20.91	150
6000	130.1	20.5	148.94
6120	127.8	20.09	149.72
6200	125.6	20.09	148.42
T7ODD
That was me, here's my log from a while back. The requested is very different. Why is Dan's requesting 0.9 bar when mine's requesting 1.1 bar if they're the same map?
Dan Cupra R
The Yellow Sub
May 2, 2006
1,514
Reading
Do you have more mods than me? Maybe that could be why, all I have is DV, Airfilter & exhaust
acidstrato
Dec 9, 2004
5,942
perhaps Dan does has something dodgy, like a fecked lambda sensor, might make the ecu pull it back? sorry dont know what values are normal for logging them.
SWANSWAY CUPRA Dealership
