Warning light - Help!
sidney1066
Can anyone clear something up for me about my new Altea please:
An amber symbol has lit up and stays on - it is a picture of a car with two wavy lines underneath. I know that this symbol stands for the esp, but my manual says that the esp warning light is a triangle with an exclamation mark inside it.
Basically, is the car with wavy lines a warning or not?
Sorry if I seem thick - I've never had a car with such a warning system before.
Thanks.
lakeside747
the light indicates that either the esp is turned off (by pressing the switch in centre console) or the there is a fault in the system. The switch for turning it off should reset when you turn the ignition off so if the light is on all the time, you should contact your local dealer
Hobbit
46
Stockport
Is that not the symbol / warning for the traction control? If it is it turns on and off with a switch in the central console, next to the door unlocking switch.
sidney1066
thanks Hobbit - I've checked the manual and it's definitely the eps.
