gazjones
vag com'd peters car today as it went into limp mode the other day, no fault codes came up and i did a log of actual v requested and a maf i can spot any problems but its different map to mine and different turbo!
there was a big drop off in boost after 5k but was spot on through midrange, anyone have any ideas from thses logs as to why it went into limp mode
Group A: '115 Group B: '002
cheers!
Code:
[code]
RPM Load Absolute Pres. Absolute Pres. RPM Load Inj. On Time Mass Flow
TIME TIME
STAMP /min % mbar mbar STAMP /min % ms g/s
0.27 1760 88 1570 1300 0.04 1720 87.2 11.07 29.47
1.07 1840 103.8 1950 1410 0.67 1800 98.5 13.12 35.94
1.86 2000 114.3 2000 1560 1.47 1920 109 14.76 42.39
2.67 2120 126.3 2060 1700 2.27 2040 120.3 16.4 49.39
3.46 2280 139.8 2050 1890 3.07 2200 133.1 18.45 58.06
4.17 2440 153.4 2010 2070 3.87 2360 147.4 20.5 70.19
4.87 2600 163.9 2000 2230 4.57 2520 160.2 22.55 80.33
5.67 2800 154.1 1990 2120 5.27 2680 163.2 23.37 81.47
6.88 3040 148.9 1980 1990 6.07 2880 148.1 20.91 80.03
8.07 3280 148.9 1970 1980 7.67 3200 149.6 21.32 91.64
8.87 3440 147.4 1950 1970 8.47 3360 148.9 21.73 94.42
9.57 3560 144.4 1950 1950 9.17 3520 146.6 21.73 96.31
10.27 3720 141.4 1950 1920 9.97 3640 142.9 21.32 98.08
10.97 3840 142.1 1960 1940 10.67 3800 142.1 20.91 102.94
11.67 3960 142.9 1970 1940 11.27 3880 142.1 20.91 104.42
12.47 4120 142.9 1950 1940 12.07 4040 142.1 21.32 108.53
13.27 4240 144.4 1960 1930 12.87 4200 143.6 21.73 114.11
14.07 4400 145.9 1960 1940 13.67 4320 144.4 22.14 118.33
14.87 4520 146.6 1950 1950 14.47 4440 145.1 22.96 124.08
15.57 4640 145.9 1950 1940 15.17 4560 148.1 23.37 129.14
16.28 4720 147.4 1940 1930 15.88 4680 147.4 23.78 130.39
17.18 4840 148.1 1950 1930 16.67 4760 147.4 24.19 135.64
17.99 4920 147.4 1930 1920 17.57 4880 148.1 24.6 137.42
18.66 5040 147.4 1940 1910 18.37 5000 147.4 25.01 140.44
19.37 5120 146.6 1950 1910 18.96 5080 147.4 25.01 142.53
20.06 5200 144.4 1960 1890 19.76 5160 145.1 24.6 143.08
20.68 5240 144.4 1970 1870 20.36 5200 142.9 24.19 141.19
21.46 5320 140.6 1970 1880 21.07 5280 141.4 24.19 141.94
22.26 5360 139.8 1980 1870 21.87 5360 140.6 23.78 143.78
22.97 5440 136.8 1990 1850 22.67 5440 137.6 23.37 142.81
23.67 5520 135.3 2010 1850 23.37 5480 136.1 22.96 143.28
24.46 5560 133.8 2000 1830 24.07 5560 133.8 22.96 141.11
25.17 5600 132.3 2020 1830 24.77 5600 132.3 22.55 141.86
25.96 5680 130.8 2030 1810 25.57 5640 131.6 22.55 142.89
26.68 5720 130.1 2020 1800 26.27 5680 130.8 22.55 141.86
27.59 5800 128.6 2000 1790 27.06 5760 129.3 22.55 142.86
28.28 5840 128.6 1980 1770 27.87 5800 128.6 22.14 142.86
29.07 5880 127.1 1940 1770 28.67 5880 127.1 22.14 144.08
