Hello all
I've had an intermittent problem with my LCR, whereby it would go into some form of safe mode at random points. At least, I assume it's a safe mode. The symptoms are the same as having very little boost from the turbo, performance disappears, there is no turbo whine or noise at all and the engine feels like a N/A engine!
So, I have run a VAG-COM scan and it has come back with two fault codes. These are 17705 and 18010.
In the VAG-COM software, 17705 comes up as:
17705 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
and looking at the list of codes at the top of this forum section, it says:
17705 P1297 Connection turbocharger - throttle valve pressure hose
18010 in the list of codes says:
18010 P1602 Power Supply (B+) Terminal 30 Low Voltage
Can somebody please shed some light on these for me? What may be the cause of these codes and what do I need to do to fix them?
Any help really would be appreciated
Rob
Rob
