I decided not to order the £250 comfort pack as only wanted auto lights and ACC in terms of options.
Realised I could buy an auto light kit off eBay for £25 for a Golf mk7/Octavia 2015, which we all know are the same as the MKIII Leon
https://www.ebay.co.uk/itm/Chrome-A...e=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
It really was a 10 min fit, only part I was not keen about was the light sensor position in the instructions.
The actual switch removal is a simple push in twist and then pull out. Feed wire and sensor through trim. Wait a few hours for the sensor to build up some charge (as would not work initially) and I then had fully operating auto lights
New switch
Recommended position via instructions
The position I moved it to and tested and gives you an idea of the size of the sensor
New switch
