Hi everybody are welcome and I write this thread for helping everybody to make mods on your cars (Seat Ibiza 2019).
I write here but I have tested in my Italian forum www.Ibizatuningclub.com all of these encodings written here.
I ask to all of you to help me to discovered new codes and to have help each others.
Many thanks to Mods and Admin to give me opened this thread here.
Many thanks to my Italian friend Zephyr to test these codes with me.
10)
Daytime running lights intensity with knob in position lights and parking function [WORKING]
NOTE: If the intensity of the rear lights does not change, enter the same value as the code "Daytime running lights in Coming / Leaving Home" of the right-hand rear light (by Ghost45 ).
1. Control Unit 09 (Central Electrics)
2. Adaptation
3. Leuchte3SL VRB36 (Front Left)
3a. Dimming_AB_3: change the value to the desired value (0 to 127) [Standard: "38"]
4. Leuchte2SL VLB22 (Front Right)
4a. Dimming_AB_2: change the value to the desired value (0 to 127) [Standard: "38"]
5. Leuchte23SL HLC7 (Rear Left)
5a. Dimming_AB_23: change the value to the desired value (0 to 127) [Standard: "127"]
6. Leuchte24SL HRA69 (Rear Right)
6a. Dimming_AB_24: change the value to the desired value (0 to 127) [Standard: "127"]
11)
Daytime running lights intensity from Radio menu selection (flag) [WORKING] (by Ghost45 )
2. Adaptation
3. Leuchte3SL VRB36 (Left Light)
3a. Dimming_CD_3: change the value to the desired one (0 to 127) [Standard: "100"]
4. Leuchte2SL VLB22 (Right Light)
4a. Dimming_CD_2: change the value to the desired one (0 to 127) [Standard: "100"]
12)
Daytime running lights intensity in Coming / Leaving Home [WORKING] (by Ghost45 )
NOTE: If the intensity does not change, enter the same value as the "Daytime running lights intensity with knob in position lights and parking function" code of the right-hand rear light.
2. Adaptation
3. Leuchte23SL HLC7 (Left Light)
3a. Dimming_CD_23: change the value to the desired one (0 to 127) [Standard: "127"]
4. Leuchte24SL HRA69 (Right Light)
4a. Dimming_CD_24: change the value to the desired one (0 to 127) [Standard: "127"]
13)
Reversing light intensity [NOT TESTED]
2. Adaptation
3. Leuchte29 KL30G A69
3a. Dimming_AB_29: change the value to the desired one [Max. 127]
4. Leuchte28RFL C3
4a. Dimming_AB_28: change the value to the desired one [Max. 127]
14)
Number of comfort arrows intermittent [WORKING]
2. Adaptation
3. Außenlicht_Blinker
4. Komfortblinken Blinkzyklen: change the value to the desired value (Max. 5) [Standard: 3]
5. Reset "Lights" to factory settings on the infotainment display.
15)
Light sensor sensitivity [NOT TESTED]
2. Adaptation
3. Assistance light function
4. Lichtsensorempfindlichkeit: change the value to:
to. "Normal" [Standard]
b. "Sensitive"
c. "Non-sensitive"
SOUNDS AND NOTICES
16)
Seat belt warning [WORKING]
Allow to turn off or change the sound of seat belts
1. Control Unit 17 (Dash Board)
2. Long Coding
3. Seat belt warning: change the value to:
to. "Version 1" [Standard]
b. "Off"
c. "Version 2"
17)
OEM alarm (Horn) [WORKING]
Enables the standard alarm that makes the horn sound, for those who did not purchase the volumetric burglar alarm with an audible alarm, proposed as an option, during the purchase phase. NOTE: with this code the automatic closing of the mirrors when the vehicle is closed will be disabled
2. Adaptation
3. Diebstahlschutz
3a. anti_theft_alarm_system: change the value to "Active" [Standard: "not active"]
3b. Akustischer_Alarm_Signalhorn: change the value to "Active" [Standard: "not active"]
3c. DWA_Alarmverzoegerung: change the value to "delay_driver_door_contact_thatcham" [Standard: "delay_driver_door_lock_cylinder_skoda"]
3d. Diebstahlschutz_mit_Anhaenger: change the value to "Active" [Standard: "not active"]
18)
Auto open / close acoustic confirmation [WORKING]
Enable a confirmation sound when the machine is opened / closed. If the volumetric anti-theft device is installed, a bit is emitted otherwise the horn is used (Management menu available in the infotainment display in: Press the machine symbol> Setup> Opening and Closing)
2. Adaptation
3. Acknowledgment Signals
3a. Menuesteuerung_akustische_Rueckmeldung: change the value to "Active" [Standard: "Not active"]
3b. Akustische_Rueckmeldung_entriegeln: change the value to "Active" [Standard: "Not active"]
3c. Akustische_Rueckmeldung_verriegeln: change the value to "Active" [Standard: "Not active"]
19)
Disable motor warning with door open [NOT TESTED]
1. Control Unit 17 (Dashboard)
2. Adaptation
3. Ignition active message, actuator: change the value to:
to. Driver door (Standard)
b. "All doors"
c. "No display"
20)
Ice warning and temperature [WORKING]
1. Control Unit 17 (Dashboard) - Code 47115
2. Adaptation
3. outside_temperature
3a. p_ice_warning_exit_temperature: change the value to the desired one [Standard: "6 ° C"] (Temperature that makes the ice symbol and the acoustic beep disappear)
3b. p_ice_warning_entry_temperature: change the value to the desired one [Standard: "4 ° C"] (Temperature that makes the ice symbol appear and emits the beep)
MULTIMEDIA
21)
Hide option AM Radio [WORKING]
1. Control Unit 5F (Information Control Unit)
2. Long Coding
3. byte_14_AM_disabler: change the value to "activated" [Standard: "not_activated"]
22)
Change volume AM / FM / DAB radio, DVD, SD player, etc. [WORKING]
2. Adaptation
3. Audio Management Input Gain Generation 2: change the following values to those desired [Standard: "-128"]
to. Radio (FM)
b. Radio (AM)
c. Digital radio (DAB)
d. Media_MFP (SD reader)
23)
Change Skin Infotaiment [WORKING]
2. Long Coding
3. Byte_17_Skinning: change the value to:
to. "Skin_2": Carbon Theme
b. Other skins to test
4. Press and hold the power button for 10 seconds until restarting
(attention please after this mod seems the radio will be slowly..so check in your car if is ok it must be evaluated by each of you)
24)
Change initial logo Infotaiment [WORKING]
To see every screen I report to this video on YT:
2. Long Coding
3. Byte_18_Screenings: change the value to:
to. "0": SEAT Standard
b. "1": SEAT FR
c. "2": SEAT Cupra
d. "3": SEAT Ecomotive
is. "5": SEAT Experience
f. "6": SEAT FR Line
25)
Adjust microphone sensitivity [Working]
2. Adaptation
3. Microphone Sensitivity: change the value to the desired one [Standard: "0 db"]
26)
Park Pilot (Optical Parking System) [WORKING]
1. Control Unit 76 (Parking Assistance)
2. Long Coding
3. Visual display for park assist: change the value in "OPS display" [Standard: "not installed"]
27)
Disable CD / DVD eject button [NOT TESTED]
2. Adaptation
3. CD eject button: change the value to "Disabled" [Standard: "Enabled"]
28)
Offroad Menu [WORKING]
Adds the Offroad menu (Wheel angle, oil temperature, etc.). It works even if you don't have the navigator, with some limitations. Touch the machine symbol> Visual> Offroad. In the absence of the standard navigator, the app will report an error as it cannot find components related to the navigator.
2. Adaptation
3. Car_Function_Adaptations_Gen2
3a. menu_display_compass: change the value to "activated" [Standard: "Not activated"]
3b. menu_display_compass_over_therhold_high: change the value to "activated" [Standard: "Not activated"]
3c. menu_display_angle_of_slope: change the value to "activated" [Standard: "Not activated"]
3d. menu_display_angle_of_slope_over_threshold_high: change the value to "activated" [Standard: "Not activated"]
4. Car_Function_List_Bap_Gen2
4a. compass_0x15: change the value to "activated" [Standard: "Not activated"]
4b. compass_0x15_msg_bus: change the value to "Comfort data bus"
4c. angle_of_slope_0x24: change the value to "activated" [Standard: "Not activated"]
4d. angle_of_slope_0x24_msg_bus: change the value on "Comfort data bus"
5. Long Coding
5a. byte_24_Navigation_System: change the value to "activated" [Standard: "Not activated"]
INSTRUMENT PANEL
29)
Virtual Cockpit Sport [NOT WORKING]
2. Adaptation
3. Sport
4. Change the value to "Display" [Standard: "Don't Display"]
30)
Stopwatch [WORKING]
Enable the stopwatch in the instrument panel. It also works with the Virtual Cockpit.
2. Long Coding
3. Lap Counter: change the value to "Yes" [Standard: "No"]
Alternative:
3. Byte 1
4. Enable Bit 3
31)
Hand test at startup [WORKING]
Only works with the analogue tachometer.
2. Long coding
3. Staging: change the value to "Yes" [Standard: "No"]
Alternative:
3. Byte 1
4. Enable Bit 0
32)
Backlight for day / night instrument panel (display and hands) [WORKING]
2. Adaptation
3. dimming_characteristic_curve_adjustment_clock_dial _day (Day)
Y1: change the value to "3" (Maximum) [Standard: "0"]
Y2: change the value to "5" (High) [Standard: "0"]
Y3: change the value to "8" (Average) [Standard: "0"]
Y4: change the value to "8" (Low) [Standard: "5"]
4. dimming_characteristic_curve_adjustment_clock_dial_night (Night)
Y1: change the value to "5" (Maximum) [Standard: "2"]
Y2: change the value to "6" (High) [Standard: "2"]
Y3: change the value to "E" (Average) [Standard: "0E"]
Y4: change the value to "1E" (Low) [Standard: "1E"]
33)
Missing tank liters [WORKING]
The same coding can be obtained by spending 10 credits
2. Long Coding
3. Byte 10
4. Enable Bit 4
34)
Compass at the bottom [NOT TESTED]
Move the compass icon to the same temperature level.
2. Long Coding
3. Byte 09
4. Enable Bit 3 and 6
OTHER
35)
Disable Start / Stop [WORKING]
1. Control Unit 19 (Gateway)
2. Adaptation
3. Start / stop start voltage limit: change the value to "12V" [Standard: "7.6V"]
36)
Fan speed in automatic mode (Climatronic bi zone) [WORKING]
1. Control Unit 08 (Air Condition)
2. Long Coding
3. Blower display in auto operation: change the value to "Activated" [Standard: "Not activated"]
37)
Mirror closing 1 click [NOT TESTED]
It allows the mirrors to be closed without holding down the machine closing button, for cars equipped with electric mirrors.
2. Adaptation
3. Spiegelverstellung
4. Funk_Spiegelanklappung_Modus: change the value to "by_look_command_via_remote_control_key" [Standard: "by_convenience_operation_via_remote_control_key"]
38)
Accelerator response [WORKING]
1. Control Unit 44 (Steering Assistance) Code: 19249
2. Adaptation
3. Driving profile switchover:
to. "Incremental, controlled over time" (Standard)
b. "Direct, controlled over threshold"
39)
Steering response [WORKING]
2. Adaptation
3. Characteristic curve of steering assistance:
to. "Driving profile selection button" (Standard)
b. "Comfort"
c. "Automatic"
d. "Dynamic"
is. "Default"
40)
Switch-on driving profile [NOT WORKING]
2. Extended Coding
3. Byte 8 (E8)
4. Activate Bit 4
(After this change, Byte 8 will change from "E8" to "F8")
41)
Battery [NOT TESTED]
Useful to change the values if the standard battery is changed.
2. Adaptation
3. Battery Adaption
4. Change the values to those indicated on the new battery. (Ah, Manufacturer, Serial Numer and Technology)
42)
Hill Start Assist Sensitivity [hill start car] [NOT TESTED]
1. Control Unit 03 (Brake)
2. Adaptation
3. Hill-start assistant
4. Hill-start assistant: change the value to:
b. "Early"
c. "Late"
43)
Hill Start Assist inclination [Hill start car](NOT TESTED)
Modification when to make the assistant intervene uphill by changing the angle of inclination. Too high a percentage will turn off HSA because too high gradients will never be reached.
2. Adaptation
3. Hill-start assistant, increase threshold
4. Steigungsschwelle Motor laüft: change the value to the desired one [Standard: "3%"]
44)
Rear trunk closure delay [WORKING]
It delays the closing of the boot if it is opened with the remote control and then closed, useful if you forget the keys inside.
2. Adaptation
3. ZV Heck
4. Freigabenachlauf_Heck_nach_Einzeloeffnung_ueber HDF-Funktaster: change the value to "active" [Standard: ???]
45)
Deflector mode roof (opening by remote control) [WORKING]
1. Control Unit CA (Sunroof)
2. Adaptation
3. Komfortfunktionen
4. Target position for comfort opening: change the value to "Tilt out position" [Standard: "Slid position"]
46)
Switch off parking sensors at a given speed [NOT WORKING]
2. Adaptation
3. Switch-off speed for parking assist: change the value to 10 [Standard: 15km / h]
47)
Operate the remote control keys even when the machine is turned on [OPERATING]
2. Adaptation
3. ZV allgemein
4. Funk bei Klemme 15 ein: change the value to "Active" [Standard: "Not active"]
48)
ESC Mode [NOT TESTED]
Select ESC ON, SPORT or OFF in the infotainment menu
2. Long coding
3. Byte 29
4. Activate Bit 06
LIGHTS ERRORS
FRONT LIGHTS
2. Adaptation
Diurnal and High Beam: [NOT TESTED]
3. Leuchte4TFL LB43 (Diurna Sx)
3a. Lasttyp: change the value in "LED Abblendlicht" [Standard: "???"]
4. Leuchte5 TFL RB6 (Diurnal Right)
4a. Lasttyp: change the value in "LED Abblendlicht" [Standard: "???"]
5. Leuchte8FL LB39 (Glare Left)
5a. Lasttyp: change the value in "LED Abblendlicht" [Standard: "???"]
6. Leuchte9FL LB39 (Dazzling Right)
6a. Lasttyp: change the value in "LED Abblendlicht" [Standard: "???"]
Fog lights: [NOT TESTED]
3. Leuchte12NL LB40 (Left Fog Light)
3a. Lasttyp: change the value in "LED Lichtmodul10" [Standard: "10 - allgemeine Scheinwerfer"]
4. Leuchte13NL RB3 (Fog Lamp Right)
4a. Lasttyp: change the value in "LED Lichtmodul10" [Standard: "10 - allgemeine Scheinwerfer"]
5. Brightness (Optional): Dimmerwert_AB_13: change the value to the desired value Max: "127" [Standard: "100"]
Arrows: [NOT TESTED]
3. Leuchte 0 BLK VL B35 (Left Arrow)
3a. Lasttyp: change the value to "allgemeine LED" [Standard: "???"]
3. Leuchte1BLK VRB23 (Arrow Right)
REAR LIGHTS
2. Adaptation
Reverse: [WORKING]
3. Leuchte28RFL C3
3a. Type_of_load_28: change the value in "LEDBlinkleuchten" [Standard: "Allemeine Gluehlampe27w Auch15TFL"]
4. Brightness (Optional): Dimmerwert_AB_13: change the value to the desired value Max: "127" [Standard: "100"]
Rear arrows: [WORKING]
3. Leuchte18BLK HLA71 (Left Arrow)
3a. Type_Of_Load_18: change the value in "LEDBlinkleuchten" [Standard: "Blinkleuchten"]
4. Leuchte19BLK HRC8 (Arrow Right)
4a. Type_Of_Load_18: change the value in "LEDBlinkleuchten" [Standard: "Blinkleuchten"]
Plate: [WORKING]
3. Leuchte25KZL HA60
4. Type_Of_Load_25: change the value to "2 * 3W" (not running in all cars)
or
"allgemeineLEDmitOpenLoadDiagnose" ( running in all cars)
Others Encodings
49)
Install OEM Camera [Working]
1 - Module 5F
2 - Long Coding
3 - Up in the right 2° page
4 - Byte 19
Activate (flag) bit 4
50)
Operate the remote control buttons even when the machine is on
It can be useful to open only the trunk without also opening the doors by the command on the door.
If you have the Keyless system you can get out of the car and close it.[Working]
Module 09 (Central Electrics) [
Security access -> 31347
Adaptation
Submenu - ZV allgemein
- Funk bei Klemme 15 ein -> active
New encodings found !
51)
Automatic closing of the windows upon locking (one click of the remote control):
Central Electric 09
Adaptations
1) Zv comfort
Komfortschliessen Brasilien ---> active
Bap Komfortschlieben--->active
52)
Motorized car mirrors [Working]
Central Electrics 09
Adaptations
Spiegelverstellung
Automatic closing of the mirrors when the car is closed [Working]
Spiegelverstellung
Funk_Spiegelanklappung_Modus: cambiare il valore su "by_look_command_via_remote_control_key" [Standard: "by_convenience_operation_via_remote_control_key"]
Menuesteverung funk spiegel anklappen--->active
Spiegelanklappen bei Wiederverriegelung -->active
Enter the variants: [Working]
1) Spiegelanklappung geschwindigkeitsabhaengig ---->moving mirrors folding function
2) Spiegel ausklappen ueber ffb auf ---->mirror folding function with only panel inserted
Lowering mirrors in reverse [Not Working Actually]
Menue Spiegel absenkung ----> Active
Spiegelabsenkung bei rüeckwäertsfahrt----> Active
Pay attention to what you change, I take no responsibility for problems.
Before start with test codes make a backup in your OBDeleven app.
Advice on how to improve this guide is accepted.
If you have encodings that are not on this list, write them in a post and I'll add them, thanks.
CATEGORIES
ACCESS CODES
LIGHTS
SOUNDS AND NOTICES
MULTIMEDIA
INSTRUMENT PANEL
OTHER
LIGHTS ERRORS
ACCESS CODES
(menù long coding)
C.U. 01 (Engine): 27971
C.U. 03 (Brake): 40168
C.U. 09 (Central Electrics): 31347
C.U. 13 (Adaptive Cruise Control): 20103
C.U. 17 (Dashboard): 25327, 47115
C.U. 19 (Gateway): 20103
C.U. 44 (Steering Assistance): 19249
C.U. 5F (Multimedia): 20103
C.U. 76 (Parking Assistance): 71679
1)
Fog lights with high beams [WORKING]
It allows the fog lights to turn on when the high beam headlight is operated, either flashing or fixed.
This coding has a "side effect": when you engage reverse gear, the front fog lights will activate. To overcome this, do the following coding as well.
2. Adaptation
3. Leuchte12NL LB40
3b. Dimming_CD_12: change the value to “100” [Standard: “0”]3c. Light_Function_D_12: change the value to “Lichthupe” [Standard: “Not active”]3d. Dimming_Direction_CD_12: change the value to “Maximize”
4. Leuchte13NL RB3
4a. Light_Function_C_13: change the value to “Fernlicht rechts” (Right High Beam) [Standard: “Not active”]4b. Dimming_CD_13:change the value to “100” [Standard: “0”]4c. Light_Function_D_13: change the value to “Lichthupe” [Standard: “Not active”]4d. Dimming_Direction_CD_13: change the value to “Maximize”
2)
Fog lights off with reverse gear engaged [FUNCTIONING]
2. Adaptation
3. Static AFS light
4. Bei_rueckwaertsfahrt: change the value to "Off" [Standard: "both sides"]
3)
Coming Home [WORKING]
Enable the CH function on the infotainment display. The low beam lights (or fog lights) and position lights come on when you get out of the car. Adjust the duration on the infotainment display.
2. Adaptation
3. auBenlicht_uebergreifend
3a. Menuesteuerung Coming Home Werkseinstellung: change the value to "active"
3b. Coming Home Verbaustatus: change the value to "automatic" [Standard: "Not present"]
[Optional] Determines which lights are turned on
4. "Coming Home Leuchten"
to. Change the value to "low beam" for low beam
b. Change the value on "fog" for fog lights
c. Change the value to "not active" to deactivate.
4)
Enable the LH function on the infotainment display. The low beam and position lights come on when the machine is opened. Adjust the duration on the infotainment display.
2. Adaptation
4. Leaving-Home_Verbausstatus: change the value to "Enabled" [Standard: "Not enabled"]
5. lho_aktiviert: change the value to "Active" [Standard: "not active"]
5)
Coming / Leaving Home with third brake light [WORKING]
Add the third brake light to the CH / LH function
2. Adaptation
3. Leuchte22BR MC9
4. Light_Function_B_22: change the value to "ComingHome LeavingHome" [Standard: "nicht aktiv"]
6)
Cornering Lights [WORKING]
Enable the "Cornering" function on cars equipped with the "Full LED Pack"
2. Adaptation
3. Leuchte12NL LB40
3a. Light_Function_B_12: change the value on "Abbiegelicht links" [Standard: "not active"]
4. Leuchte13NL RB3
4a. Light_Function_B_13: change the value to "Abbiegelicht rechts" [Standard: "not active"]
5. Static AFS light
5a. Vorschrift: change the value to "FMVSS_517_108" [Standard: "Off" or "ECE R119"]
[Optional] Disable the Cornering function at a given speed.
5b. Obere_Geschwindigkeitsschwelle: change the value to the desired speed.
7)
Front daytime running lights off with the handbrake on [FUNCTIONING]
It allows the parking lights to be switched off when the hand brake is applied.
NOTE: Incompatible with "Daylight ON / OFF menu"
2. Adaptation
3. Außenlicht_Front
4. Tagfahrlicht_Dauerfahrlicht_bei_Handbremse_abschalten: change the value to "active" [Standard: "not active"]
8)
Daylight lights off with knob set to 0 [WORKING]
(Follow the code up to point 3a to switch off only the front DRLs and leave the rear ones on)
2. Adaptation
3. Außenlicht_Front (Front)
3a. Tagfahrlicht_nur_in_Schalterstellung_AUTO: change the value to "active" [Standard: "not active"]
4. Leuchte23SL HLC7 (Rear Left By Ghost45)
4a. Light_Function_A_23: change the value in "Parklicht links" [Standard: "nicht_definiert_28"]
4b. Light_Function_B_23: change the value to "Standlicht" [Standard: "Parklicht links"]
5.Leuchte24SL HRA69 (Rear Right by Ghost45)
5a. Light_Function_A_24: change the value to "Parklicht Rechts" [Standard: "nicht_definiert_28"]
5b. Light_Function_B_24: change the value to "Standlicht" [Standard: "Parklicht links"]
9)
Daytime running lights with selection (flag) ON / OFF radio menu [WORKING]
Adds a new item in the menu that allows you to turn on / off the DRLs, instrument panel, license plate lights and climate control lights. Vehicle settings> Lights> Daytime running lights
NOTE: Incompatible with "Daytime running lights off with handbrake on", otherwise the DRLs do not light up from the menu.
2. Adaptation
3a. Tagfahrlicht_Aktivierung_durch_BAP_oder_Bedienfolge_moeglich: change the value to "active" [Standard: "not active"]
3b. Tagfahrlicht_Dauerfahrlicht_aktiviert_Zusaetzlich_Standlicht: change the value to "active" [Standard: "not active"]
4. Leuchte23SL HLC7 (Rear Left by Ghost45)
5.Leuchte24SL HRA69 (Rear Right by Ghost45 )
CATEGORIES
ACCESS CODES
LIGHTS
SOUNDS AND NOTICES
MULTIMEDIA
INSTRUMENT PANEL
OTHER
LIGHTS ERRORS
ACCESS CODES
(menù long coding)
1)
2. Adaptation
3. Leuchte12NL LB40
4. Leuchte13NL RB3
2)
2. Adaptation
3. Static AFS light
3)
2. Adaptation
4)
2. Adaptation
5)
2. Adaptation
3. Leuchte22BR MC9
6)
2. Adaptation
3. Leuchte12NL LB40
4. Leuchte13NL RB3
5. Static AFS light
7)
2. Adaptation
3. Außenlicht_Front
8)
2. Adaptation
9)
2. Adaptation
10)
2. Adaptation
11)
2. Adaptation
12)
2. Adaptation
13)
2. Adaptation
4. Leuchte28RFL C3
14)
2. Adaptation
15)
2. Adaptation
b. "Sensitive"
c. "Non-sensitive"
SOUNDS AND NOTICES
16)
2. Long Coding
b. "Off"
c. "Version 2"
17)
2. Adaptation
3. Diebstahlschutz
18)
2. Adaptation
19)
2. Adaptation
b. "All doors"
c. "No display"
20)
2. Adaptation
MULTIMEDIA
21)
2. Long Coding
22)
2. Adaptation
to. Radio (FM)
b. Radio (AM)
23)
2. Long Coding
24)
2. Long Coding
b. "1": SEAT FR
c. "2": SEAT Cupra
25)
2. Adaptation
26)
2. Long Coding
27)
2. Adaptation
28)
2. Adaptation
5. Long Coding
INSTRUMENT PANEL
29)
2. Adaptation
3. Sport
30)
Stopwatch [WORKING]
2. Long Coding
Alternative:
3. Byte 1
4. Enable Bit 3
31)
2. Long coding
Alternative:
3. Byte 1
4. Enable Bit 0
32)
2. Adaptation
33)
2. Long Coding
3. Byte 10
4. Enable Bit 4
34)
2. Long Coding
3. Byte 09
OTHER
35)
2. Adaptation
36)
2. Long Coding
37)
2. Adaptation
38)
2. Adaptation
39)
2. Adaptation
b. "Comfort"
c. "Automatic"
d. "Dynamic"
is. "Default"
40)
2. Extended Coding
3. Byte 8 (E8)
4. Activate Bit 4
41)
2. Adaptation
3. Battery Adaption
42)
2. Adaptation
b. "Early"
c. "Late"
43)
2. Adaptation
44)
2. Adaptation
3. ZV Heck
45)
2. Adaptation
46)
2. Adaptation
47)
2. Adaptation
3. ZV allgemein
48)
2. Long coding
3. Byte 29
4. Activate Bit 06
LIGHTS ERRORS
FRONT LIGHTS
2. Adaptation
REAR LIGHTS
2. Adaptation
Reverse: [WORKING]
3. Leuchte28RFL C3
Plate: [WORKING]
or
Others Encodings
49)
1 - Module 5F
2 - Long Coding
4 - Byte 19
50)
Adaptation
51)
Central Electric 09
Adaptations
1) Zv comfort
52)
Adaptations
Spiegelverstellung
Spiegelverstellung
