Installing LED footwell lights on Seat Ibiza Cupra
These are the LED's I will be using:
I picked them up off of Amazon for quite cheap but I know they are a decent quality.
I've already run the wiring in on the passenger side it looks like this:
Step 1 - Remove the fuse for the interior light.
Step 2 - Remove the interior light cover.
Step 3 - Unscrew the interior light (two screws).
It should fall down like this.
Step 4 - Take out the interior light bulb and loop the wire and wrap it around the interior light bulb holder.
Step 5 - Remove the sun-visor and pull the A-Frame cover off slightly.
Step 6 - Feed the wire through the hole behind the interior light.
Step 7 - Bring the wire along the roof lining down the A-Frame.
Step 8 - Using fine sandpaper, rub the surface of the LED's so the light scatters better as LED's can be quite direct.
Step 9 - Connect the LED's to the wire from the interior light and use bullet connector to hold them tightly in place.
Step 10 - Attach the LED lights in the footwell! These LED's came with adhesive on the back but I cable tied as well just incase the adhesive fails at a later point.
And there we have it! LED lit footwells! I will take a few photos tonight when you can really see them. But I am really happy with how it went. It took about 2 hours and is a really cheap mod!
Any queries or questions leave a comment and I will respond ASAP!v
Author
JoshRedCupra
Views
3,652
First release
Last update
