jcbmally
Infotainment system How to disable Eco Tips
Eco tips tell you to close windows etc, not to be confused with Eco Assist that tells you of incoming roundabouts/foot of pedal etc.
Start car, once everything is loaded up select car symbol on bottom right hand side of the infotainment screen.
Select interior.
Select infotainment
Scroll to Eco tips and move slider.
As stated at the top of this page Eco assist is different. It warns you of roundabouts etc, even warns you of bends etc when you have ACC/Travel assist activated and will slow the car then return to the set speed, pretty cool TBF. Eco Assist defaults on every time the car is restarted, well it does in mine.
On the driver assist screen swipe/scroll left to Eco assist.
Click on information.
It tells you a little bit of info there. I found out it intervenes with ACC/Travel assist by chance.
Hope this helps.
Author
jcbmally
Views
9,604
First release
Last update
5.00 star(s) 1 ratings
More resources from jcbmally
Latest reviews
Clear and simple, thanks.
jcbmally
jcbmally
Thank you.
