Coming up too often now - so a sticky is on order
from: http://www.ross-tech.com/vag-com/cars/immobilizer2.html
ECU Swapping with Immobilizer 2
Posted 24 Jun. 2003
Ross-Tech is not responsible for any damage or problems that may result from following these instructions. They are to be used at your own risk.
Immobilizer II:
The immobilizer will prevent the car from running without a matching key microchip. There is a symbol in the instrument cluster showing a key inside a car. If a new (or different ECU) is installed in the vehicle, the immobilizer will prevent the car from running and will cause the symbol to flash. Here is the procedure to introduce a new ECU to the instrument cluster. This must be performed each time ECU's are exchanged. This does not apply to installing a "chip" in the same ECU that is already aligned with the car.
Immo-3 knows your car's VIN. Access 17-Instruments (or separate 25-Immobilizer on vehicles that are set up that way) and look at the first "Extra" field.
If you see something like: "Immo-ID VWZ7Z0W0648696" You've got Immo-2 (or maybe even Immo-1 in earlier non-US models).
If you see something like "WVZKB58001H231169 VWZ7Z0W0648696" You've got
Immo-3. The first 17-digit string is the VIN. The second 14-digit string in the Immo-ID.
Install the new ECU in the car
[Select]
[17 - Instruments]
[Adaptation - 10]
Leave channel at "00"
[Read]
[Save]
[Done, Go Back]
[Close Controller, Go Back - 06]
[Exit]
Turn ignition OFF for 15 seconds. Start vehicle.
Note: For cars with a separate Immobilizer (Includes 2000+ EuroVan, Cabrio, and many older non-US models), use [25 Immobilizer] instead of [17 - Instruments]. The rest of the procedure is the same.
Posted 24 Jun. 2003
Immobilizer II:
[Select]
[17 - Instruments]
[Adaptation - 10]
[Read]
[Save]
[Done, Go Back]
[Exit]
