SEAT PORTABLE SYSTEM [GARMIN] Skins & Hacking
Nov 15, 2024
Hi Ive just looked through this whole thing and I’m having a problem with my Harmon screen I don’t have access to the performance screen at all even tho my car is a cupra I don’t know if it’s been switched if that can cause this but would really like some help on how to get it or do I have to buy a new screen all together thanks.
Chillout
212
276
Don't get a new screen. Did you try a factory reset and setting up the device again?
Or put it in developer mode, where you can choose your model manually:
Try this :
create a file:
\VwBrandDevice\Settings\UserSettingsDevMode.default with notepad
with contents:
Code:
<?xml version='1.0' encoding='iso-8859-1'?>
<Settings>
    <Active>1</Active>
</Settings>
make sure it's .default
then create a file called branddevice.reg and put it to the root /.
reboot and then you maybe able to manually chose your brand/skin. (All settings (route profiles, last targets...) will be lost)
