1940 software update - Get it or wait?
spembo
56
10
Had this done yesterday.
Reboots wern't happening for me that often, but did. Thing i wanted it solve was it keep trying to call breakdown, did it first drive this morning :( Annoying having to keep cancel it whilst trying concentrate on the road
Mirador
30
West Sussex
I didn't think
I didn't think 1940 was OTA? (according to other contributors unless future plans). Left mine at the dealers ready to pick up 5 hours later and so far so good.
Yes possibly it started then did a current software level check and aborted itself.
Yesterday though I received another OTA update so I took it. OUI2. Just 1 part this one. See if there's any difference. Listed a few fixes, one being the SOS which will be good.
Reactions: Yern
Mirador
30
West Sussex
Well I'm pleased to say that the usual two locations that have always triggered the popping sound has not happened since the recent OTA update. Let's hope it continues. I know my software version is old but on the whole works very well
Jammers
32
8
Does anybody have software 1940 and still unable to become primary user issue? Mine just loads forever and nothing I can do to fix it?
once mine had updated to 1940 it received a further update to solve the very issue you have mentioned.
Jammers
32
8
Under warranty. They’d likely charge a fortune after. You can download the update files from one of the sponsors on this forum though and do it yourself, but obviously the risk is on you if it gets bricked.
Over the air this week so saved me an argument with the dealer.
Reactions: Alex667
witek_77
94
44
PL
I will share with you the file I made from. Link for 1940 is HERE and link for 1969 is HERE. You do it at your own risk. download the file to disk, unpack it using winrar. format the pendrive to fat32 or exfat. Copy folders DATA and META for pendrive. Start the car. it's more safe than a battery. Insert the pendrive, press and hold the menu button (this on left corner with 3 lines or 4 dots) up to the service menu and press update. We're taking off down there. we wait about 15 minutes. If everything is OK, click resume and the system will restart. the manual is also available for download. Thanks for Jakub F. for file. File verified by 5 people on the Polish forum. Including me. I have update from 1896 to 1940 few months ago and now from 1940 to 1969. I don't know if you can update from older versions.
96
45
good morning everyone, a few months ago I updated my car from the 1896 version to the 1940 version; Do you know how to update the other units as well since I currently only updated the 5f?
Feb 22, 2022
96
45
View attachment 39453 View attachment 39454 View attachment 39455 View attachment 39456 View attachment 39457
1)What improvements have you found compared to the 1940 which I also installed via USB? 2) how could we also obtain the update of other units such as the A5 unit?
witek_77
94
44
PL
I updated 2 days ago and haven't driven since then. Winter surprised us and I didn't have to leave the house. other drivers, unfortunately, probably only via ODIS. I would also like to make a counter because I do not have view 2 from FR. I only have cupra.
Feb 22, 2022
96
45
It seems to me that the USB update procedure from 1940 to 1969 is identical to the previous procedure for updating from 1896 to 1940, correct? only in this case, can I directly upgrade to the 1969 since I already have the 1940?
I would like to update my A5 to get the new lane change function but I need the parameters
witek_77
94
44
PL
I have update from 1940. Procedure is the same. I was testing now and one small ota came right away. the same as in 1940 with the main user. Nothig change for now
Feb 22, 2022
96
45
once I have extracted the rar via 7-zip (exactly as I did for the 1940 version), is it correct that I also find a "MQB37_SE_1969.00.ver" file together with the two "DATA" and "META" folders?
witek_77
94
44
PL
Yes. I also copied this file to a pendrive. I don't know what it's for but everything went fine
Feb 22, 2022
96
45
where could we find the files to be able to update the other units via ODIS, in particular the a5 unit?
