Good evening all
I have read numerous pages on this subject and I still have the issue.
I will explain my problem as quick as possible amd if someone can help I will send the biggest create or beer your way.
Right here goes I purchased a seat leon fr550 which seemed perfect until the glow plug light started flashing,so I took it for a diagnostic test.
After the test it cane up that I needed two Injectors replacing and there was a turbo issue.
So I took it to my local lions van specialist they did a diagnostic test and also found the same.
So they replaced 2 injectors and replaced turbo actuator.
I thought awsome job done,I took it for a drive light came back on so back to lions it went.
They did a full inspection and found out the div who had the car before had smashed the inside of the dpf out.
So they did more investigations to find he'd aslo put an absolutely shocking remap on the car too.
So they got In touch with seat got hold of a standard remap and put it back to factory.
They then cleaned the inside of the dpf and blanked it off.
While doing so they also got a proper dpf delete for my car thr car fan so much better.
I tool it out for a drive again glow plug light came on.
They put diagnostic on it and it came up with air leak fault.
So they put a smoke machine on the car and found two boost hoses were split and the manifold had a massive split in it.
So the manifold and hoses were replaced.
Again I thought job done.
Took it out glow plug light still on!
Put diagnostic kit on it no fault codes!!!
Does anyone have any ideas what could be causing the issue please?
Again if anyone can help there's a massive create of beer in it for you.
Many thanks for reading my essay matt
