Leon097
43
16
The Netherlands
Option 2 for 1447 you need Mib Tool and also VCDS / Obdeleven to get the skin changed.
Option 1 if you look at it you may not need either. I've not looked at it.
Option 3 (You only need the navigation FeC, performance gauge etc) you'd need Mib Tool same as option 2. You can have ago at that. Easy enough if you dont want to bother with the final release of the mib2 high software. Not sure whether that was ever rolled out due to the issues on skin and language file. No doubt I'll be corrected if it was. There is a roll back in Mib Tool to the firm edit it does if you dont like it. Option 1 is the more streamlined to option 2.
Thanks! It's totally clear now. :)
Nov 12, 2021
11
Not within the 03xx series as I understand it... let other reply to that. The main thing is to let the unit do the updates via as many reboots it needs powered up with the engine running. There are more experts on here on this than me 😍. Stress power since if the unit looses power you are comprimised. All risk is down to you.
Thank you for the help. everything worked fine
Reactions: Tell
PaulusB
132
19
Maybe I am lazy but which files do I need to update my retrofit mib2 technisat SW 0245 HW H24 to the latest version. It's the version with gps and dab.
And after that I can enable all options like AA AC etc.
nameless
48
24
if you like risk... you can tey 330 and then 346... but at you own risk... see post before...
jpmedia
21
14
install beta fw?Why you know that on changing drive profiles freezing?unit stuck slow etc...
nameless
48
24
if you want the new picture menu and no more the first one (carousel menu) it's the only solution... 346 is not a beta but 330 yes and you have to pass, and yes you can have strange behaviour when you firstbput this beta and need a vcds cable or something to correct some stuff...
jpmedia
21
14
0346 has bugs.....if you look meta then its a linked fw update .......so 02xx change to 03xx signed officially...for sure just for internal test s for new hw30 devices from 2017....
Billys_CupraST300
21
7
39
Menden Germany
Hi Guys,
Can someone please have a look and tell me if there is any available update for me? I have tried to read the topic but there are posts here and there and if you dont have any experience with this its a little bit difficult to understand all of these things.
I am attaching some pics and if there is a guide for someone who haven't done this (noob guide) that would be awesome.
I don't want to lose anything that i already have unlocked.
Tell
OHi Guys,
That's a mib2high follow from here:
There will be grousing. Post 1065. You got options 1 (AIO method) and 2 (previous method). Option 3 if one of the guys does you a dummy for mib tools. Don't think it has that one built in for you. Option 1 is now the preferred, although we haven't had any reported back user experience although with option 2 we have - linked to above. I stayed with option 3 just taking the FeC upgrade of Mib Tool. Option 1 and 2 gives you the very latest and probably last and probably never released mib2 high software with all FeCs. I'll be told if I'm wrong.
Suspect some of the posters here worked on option 1 which is why they moaned when I named the previous way of doing it which had user experience. It has been tested thou. Original release which was obtained was missing files so you had to back top up the missing files from the previous release using the units built in import system, part upgrade of missing files. Option 1, they worked the missing files into it and corrected the skin issue which had bugged people.
In the UK the boards retrofitter sponsor can get you up to 1447 (East Yorkshire) if confident you can do it yourself for free.
The x176 map release which you are on is one of Seats unique funny releases. With the FeC upgrade you can move to the latest 195 maps (November 2021 release). That's all part of the package upgrade in the options is to give life long navigation FeC etc. Map update you do yourself.
Reactions: Billys_CupraST300
Jan 2, 2021
For those that need the files hire it is from the Spanish forum together with some G translate info.
My unis is 5QA035858 HW24 SW245, the update to 346 went well with no problems at all.
330
https://drive.google.com/open?id=1wvEmQkI1eyyWFSxrwje9kap7tSOmXdaf
346
https://drive.google.com/open?id=1n08Fdw3C53futzb3b8sv5dOEwn2wIYv7
Mib2 - 6.5 "screen
Version of the update: 0330
(Beta) Install this and then 0346. The 0330 is a Beta and has known bugs (Do not be afraid if you see strange things) are solved by updating to 0346.
Equipment compatible with these updates: MIB 2GEN 6.5 "HW: 024 FW: 0245
Unzip the file. The final structure should be as follows:
Folder: powerc
Folder: mainplus
Folder: main
Folder: DUW014
Folder: DUW013
Folder: DUE410
Folder: DUE409
Folder: DUE406
Folder: DUE405
Folder: cpuplus
Folder: cpu
Folder: bluetooth
File: metainfo2.txt
Copying the folders and the file to an 8 GB Class 10 SD card (If you use a slow card, the update can be eternalized, with the Class 10 it takes about 40 minutes)
Update version: 0346 (Latest version compatible with the device) (Pre-install 0330)
Equipment compatible with these updates: MIB 2GEN 6.5 "HW: 024 FW: 0245 and logically HW: 024 FW: 0330 (If any)
Folder: powerc
Folder: mainplus
Folder: main
Folder: DUW070
Folder: DUW069
Folder: DUW013
Folder: DUW014
Folder: DUE410
Folder: DUE409
Folder: DUE406
Folder: DUE405
Folder: cpuplus
Folder: cpu
Folder: bluetooth
File: metainfo2.txt
MIB2 6.5 "update method
CHECKED AND SOLVED TO ERRORS PRESENTED
As explained above, to update the MIB2 from 0245 to 0346, it must be updated before 0330.
Therefore, first perform the 0330 following all the steps described below and then the 0346 and again the same steps and avoid unpleasant surprises.
1) Use a minimum SD 8GB and can be Class 10 (It is much faster)
2) Format the SD card in FAT32
3) Copy the data to the SD card (All folders and the TXT file must remain in the root of the card)
4) Insert the SD card into the SD1 Housing of the glove compartment.
5) Put the car contact (Do not start the engine under any circumstances or turn off the Infotainment)
6) Press the Infotainment Menu button and press and hold until the service menu exits.
7) Select SW Update and click on Update.
8) Wait for the system to give us an Update Done message and confirm.
9) We connect the diagnostic device (Vagcom, OBDeleven, etc.) and do a Scan.
10) We erase all faults.
IMPORTANT
1)
Güncellemeler, SD kart Sınıf 10 ise, her biri yaklaşık 30 dakika sürer, eski kartlarda çok daha uzun sürer.
2) Bir USB'den yükseltmeyi deneyebilirsiniz, ancak her zaman işe yaramaz, USB çoğu durumda marka, çip vb. ile biraz çelişir. Güncelleme yapmazsanız hiçbir şey olmaz, size okuyamadığını söyleyecektir. veri.
3) Bir SD ile güncelleme yapmaya çalışırken, yanlış yaptığınız bir şey olan veri hatası alırsanız. Kartı yeniden biçimlendirin veya kartları değiştirin.
Güncelleme sırasında:
1) Kontağı araçtan çıkarmayın veya Bilgi ve Eğlence Sistemini kapatmayın.
2) Güncelleme sırasında motoru çalıştırmayın. (Başlamadan önce başlatabilirsiniz, ancak zaten güncellenmeye başladıysa başlatmayın)
3) Hiçbir koşulda otomobil tüketicileri kullanmamalısınız (Isıtma, klima, OBDII, Bluetooth bağlantıları vb.).
GEREKSİZ RİSKLERDEN KAÇININ. Güncellemeler ciddi bir şey, arabada dolaşmayın, hava soğuksa ısınırsınız ya da başka bir zaman ararsınız.
Bu yönergeleri izleyemiyorsanız, güncelleme yapmamanız daha iyidir.
4) Pil gücünün düşük kalması riskini almak istemediğinizi düşünüyorsanız, işleme başlamadan önce bir pil şarj cihazı bağlayın ve bitene kadar açık tutun.
Normalde güncellemelerden sonra SVM (Yazılım Sürüm Yöneticisi) doğrulanmalıdır.
Sistem bir hata verecektir: 1555 - Kalıcı ve silinmemiş Yazılım Sürümü Yönetimini Kontrol Edin.
Bunu çözmek için şu adımları izleyin:
5F'ye giriyoruz
Uyarlamalar
Kurulum değişikliğinin onayı
Bize gösterdiği değeri kopyalıyoruz (XXXX)
XOR'a sahip bir hesap makinesi kullanıyoruz (örneğin Bitsel hesap makinesi)
Onaltılık olarak sahip olduğumuz değeri koyarız.
XOR veriyoruz.
Bu C9D2 değerlerini koyuyoruz ve hesaplamak için = sembolünü veriyoruz.
Bize koyduğunuz değeri, Montaj değişikliğinin Onayı'na koyduk ve kabul ediyoruz.
Kabul ettikten sonra, başlangıçta sahip olduğumuz değere göre değerin değişmediğini göreceğiz. BU NORMAL.
VagCom ile yapacaksanız ortada bir boşluk bırakın. (XX XX) tekrar yerleştirerek.
Tamamlandığında, Taramayı yeniden yapın ve hatayı kalıcı olarak silin.
merhaba güncelleme yaptıktan sonra tam link bölümü gitmiş nasıl geri getirebilirim şimdiden teşekkürler
Jan 2, 2021
Bu, buradan bir mib2high takibidir:
Küfür olacak. 1065 sonrası. Seçenek 1 (AIO yöntemi) ve 2 (önceki yöntem) var. Seçenek 3, adamlardan biri size mib araçları için bir kukla yaparsa. Bunun sizin için yerleşik olduğunu düşünmeyin. Seçenek 1 şimdi tercih ediliyor, ancak herhangi bir geri rapor edilmiş kullanıcı deneyimimiz olmamasına rağmen, 2. seçenekte - yukarıda bağlantı kurduk. Ben sadece Mib Tool'un FeC yükseltmesini alarak seçenek 3'te kaldım. Seçenek 1 ve 2 size tüm FeC'lerle birlikte en son ve muhtemelen en son ve muhtemelen hiç piyasaya sürülmemiş mib2 yüksek yazılımını sunar. Yanlışsam söylerim.
Buradaki posterlerden bazılarının seçenek 1'de çalıştığından şüpheleniyorum, bu yüzden bunu yapmanın önceki yolunu kullanıcı deneyimine sahip olarak adlandırdığımda inlediler. Sende denendi. Edinilen orijinal sürüm eksik dosyalardı, bu nedenle önceki sürümdeki eksik dosyaları, içe aktarma sisteminde yerleşik birimler, eksik dosyaların kısmi yükseltmesini kullanarak yedeklemeniz gerekiyordu. Seçenek 1, eksik dosyalar üzerinde çalıştılar ve insanları rahatsız eden cilt sorununu düzelttiler.
Birleşik Krallık'ta pano güçlendirme sponsoru, kendiniz ücretsiz olarak yapabileceğinizden eminseniz sizi 1447'ye (Doğu Yorkshire) kadar çıkarabilir.
Üzerinde bulunduğunuz x176 harita sürümü, Koltukların benzersiz komik sürümlerinden biridir. FeC yükseltmesiyle en son 195 haritaya geçebilirsiniz (Kasım 2021 sürümü). İşte bu kadar paketin bir parçası olan yükseltme seçeneklerinde ömür boyu navigasyon FeC vs. vermektir. Harita güncellemesini kendiniz yaparsınız.
Jan 2, 2021
Ayrıca, MIB2 ünitesinin 8" ekranla çalışması için olması gereken minimum bir SW sürümü vardır. Neyse ki, devam etmeden ve ekranı satın almadan önce bunu okumuştum.
SteveGSXR600K1
588
193
It's on the Spanish website....
3) In the Mib2 (6.5 "screen) in some cases the Mirrorlink connection option disappears from the screen.
To fix it:
With OBDeleven:
Module 5F
- Vehicle configuration - Options
----- Mirror_link - (Function off_HMI off)
Change it to Function On_HMI On
If you do not let it change, we go to Change session in 5F and change to Mode developer
When it appears on the screen again, restart the Infotainment to read the new parameters.
With VAgCom
Module 5F
Adaptations menu
Vehicle Configuration
Search Mirrorlink and change the value from 0 to 1
Reactions: alperen26
Jan 2, 2021
İspanyol sitesinde var....
3) Mib2'de (6,5" ekran) bazı durumlarda Mirrorlink bağlantı seçeneği ekrandan kayboluyor.
Tamir etmek için:
OBDeleven ile:
Modül 5F
- Araç konfigürasyonu - Seçenekler
----- Mirror_link - (Fonksiyon kapalı_HMI kapalı)
İşlev On_HMI Açık olarak değiştirin
Değişmesine izin vermezseniz, 5F'de Oturumu değiştir'e gidip Mod geliştiricisine geçiyoruz.
Ekranda tekrar göründüğünde, yeni parametreleri okumak için Bilgi ve Eğlence Sistemini yeniden başlatın.
VAGCom ile
Modül 5F
Uyarlamalar menüsü
Araç Yapılandırması
Mirrorlink'i arayın ve değeri 0'dan 1'e değiştirin
çok teşekkür ederim ilginiz için
Tamir etmek için:
OBDeleven ile:
Modül 5F
VAGCom ile
Modül 5F
Uyarlamalar menüsü
Araç Yapılandırması
Çok teşekkür ederim ilginiz için çok canım sıkılmıştı yarın OBDeleven ile deneyeceğim size sonuç hakkında bilgi veririm
Reactions: SteveGSXR600K1
_Dejan_
144
66
Hi @Tell I’m said that I will first read this thread, but I’m not :) I will do this in next days...
We are talk in MAP update thread about FEC's and other things…
What exactly do you meen that I can enable offroad and performance screen?
This two I have enabled by default also stopwatch/laptimer:
So my car came with all EU options which has been available to select in configurator(Except MapCare)... Options which maybe can be affected with FEC update are:
- VirtualCockpit
- Headunit have jukebox, wifi, bluetooth, AndroidAuto, MirrorLink, DAB, TMC, Traffic Sign Recognition(TSR in kmh), voice commands... It have by default enabled Stopwatch, offroad, performance display page...
- Wireless charger
- BeatsAudio
- ACC + FrontAssist + LaneAssist + High Beam Assist + Stop&Go Traffic Assist
- Front & Rear PDC
- Rear Camera
- Kessy
I’m not sure if all this can be effected by FEC update and maybe I’m miss something to specify and is also installed...
My current FEC’s are:
00030000
00040100
00050000
00060100
00060200
00060300
00060400
00060800
00060900
00070200
0730001c
07300028
07300028 NOT VALID
Is possible backup installed FEC's and only add MapCare FEC for example 073000EE or 073000FF(Im not sure which one is correct)?
Right now after quick reading I'm see that MIB tool and MIB2 Toolbox(https://github.com/jilleb/mib2-toolbox) are two different things… Few years ago I’m try install MIB2 Toolbox but it failed because it has been in early development state… Need to check MIB tool and detailed research how to modify my unit to add only MAPCare option and not lose any other default option… Of course I need to make backup of my unit if tool support it…
Tell
- VirtualCockpit
- Wireless charger
- BeatsAudio
- Front & Rear PDC
- Rear Camera
- Kessy
00030000
00040100
00050000
00060100
00060200
00060300
00060400
00060800
00060900
00070200
0730001c
07300028
07300028 NOT VALID
Looks like you have the two off road and performance FeCs. It's the jilleb one you want available on:
Login guest, guest
The zip icon is the software. The link is Mib Tool in that directory. That tallies with what I gave you on the navigation thread. That should install following the documentation I gave you over there which is found above as "option 2".
The Mib Collective experts are here. I guess it wont be an issue that you have an invalid FeC as per above. Mib Tool adds to the list of FeCs in the unit and just looks at the collective set of FeCs ignoring the invalid ones. I'll be told if I'm wrong.
The story so far for others is that 3 year Mapcare ran out more or less but a garage messed up the 3 year Mapcare FeCs loosing what was in the car. Given they were to run out in Feb 2022 I said try Mib Tool since Dejan had compatible firmware 1219. Conversation starts here.
I didn't think it warranted a firmware update as such just a bit of FeC work carried out with Mib Tool. @jpmedia I'm sure will step in if you run into problems. It looks straightforward in principle if all goes well.
Reactions: _Dejan_
MIB-Wiki
70
55
Get M.I.B and run patch, missing FECs will automatically be added.
(Alternative would be the AIO update, would also patch and add FECs)
After reboot install latest P195 maps and you are done until next map update .
mib.mibsolution.one
Gesendet von iPhone mit Tapatalk
Reactions: _Dejan_ and Tell
Dec 23, 2021
Hi,
Can anyone advise me on how i can update my software version ? There are a few bugs with it so i'm hoping an update will resolve the issue.
Part Number : 5F0035869
Hardware Version : 164
Software Version : 0086
Any help appreciated. I don't really want to take it to a dealership and end up paying £100+ just for a software update.
MIB-Wiki
70
55
Train version is always better to identify the SW version and unit type.
