I have recently bought a Cupra ST300 with Stage 1 map and I am getting a wastegate type chatter noise sometimes when lifting off the throttle at low revs or downshifting from the passenger side. It might be making the noise when driving hard but I can't hear it above the other engine noise.
Not a great recording but around 3/4 through the recording you should be able to hear the noise here : Cupra flutter It sounds much louder in person
I can't see any obvious mods so wanted to check if I have an issue. The car drives fine but worried there might be a problem or I am causing damage driving it like this.
