Chillout
212
276
whoops, posted in the wrong forum
Rich.T
1,609
932
Just the very edge of the inside left wheel was touching the coilover thread but only reversing? Weird. Probably need a proper alignment!
No fuss as i had some spare spacers to put on.
Itll be camber (if theres any adjustment on them) or wheel offset.
*Worth getting it checked sooner than later. It could wreck your tyres.
*Yeh, i know i like spending other people's money aswell as my own lol
Connor H
1,023
503
Essex
My car has needed an alignment for soooo long but i keep having to go back in and take things off etc lol . Im pretty certain just by eyeballing it the subframe needs adjusting, i believe on this AUQ platform i have no camber adjustment at all. But on the back of that i read. very cool breakdown on the mk4 of how being as low as i am introduces positive camber on hard cornering . Its not a track car so im probably not going to raise it up, but i will get some of these:
Reactions: Rich.T
Connor H
1,023
503
Essex
OR these but i cannot find much info about the ride quality n that. Not that the powerflex bushes are remotely smooth lol
Manic172
Dec 4, 2018
1,349
1,401
Hemel hempstead
www.seatcupra.net
If you go for theses have a look a cb autos. You can go for the 30mm bushes then get the insert so they then fit your arms and you have even less Bush movement. Pop to my yard 1 evening if you want mate I have some in a set up you can have a look at
Connor H
1,023
503
Essex
Yeah ill be well up for that mate. love to pick your brains. I get paid this weekend so can pop up whenever! Weekends good for you?
iammooks
1,784
1,172
The more I look into boost gauges the more of a ball ache it seems to be on a diesel. I'm reading that the best place to plumb it in is just below the elbow boost pipe that connects to the EGR and that you have to cut a thread in the plastic. I'm not sure I trust a thread I've cut into plastic with that much pressure.
Any other TDI people running boost gauges who can advise?
On top of that, what's the best a-pillar pod.that actually fits?
Sl1ced
797
404
I’m sure thai was selling a complete pillar a while ago
Sl1ced
797
404
Ah ****. [mention]iammooks [/mention] hit 1.8t parts for sale on Facebook someone will have one
Sl1ced
797
404
Well I’ve tagged the wrong person and it won’t let me edit it. Win some loose some
Connor H
1,023
503
Essex
Personally used the vent mount instead, i couldnt find any pillar pods except for a website that looked quite old.
Rich.T
1,609
932
All a boost gauge will tell you is that you need to stop stalling and get on with cleaning out the manifold and turbo 😉
On a more serious note.
Is there anything that can be done on the pd to stop boost leaks?
Those hose ends with the C lips are awfull.
My pipe ends used to wobble about if i grabbed them and i had to replace 2 pipes as they would occasionally blow out under pressure due to the little nipple bits wearing down on the metal ends due to the movement.
Rich
