Right been on holiday but now Got a day at the workshop... started stripping the rear axle to fit the new one. Got new axle. Stubs ,bearings, and 300mm conversion kit and cupra r calipers to go on.. But hit a
problem. Not got a 30mm bi hex here so now that's stopped lol
So now it's for the axle hanging brackets to the under side and then fix the axle at least lol.and the the shocks and springs
I got new bolt kits from a brilliant company called vag bolts. They do every bolt needed. I am slowly fitting complete new set as I go. Shocks are gas with hight ,damping and rebound adjustable settings.. hopefully I can remember to grab a socket from work tomorrow then I can finish off the rear end. I gotta remove the front subframe again as I have some thing special comming next week. So I may have my front end set up for sale... new subframe with solid mounts. Then the lower armshave the powerflex camber adjustable bushes in the front. But they are the 30mm diameter in the 45mm arms but with the cbauto sleeve to have reduce movement and flex. And the rear bush is the spherical bearing set up from powerflex too.. I will price it all up later so see what the sale price might be ... Right best get on and fit some of these new buts I keep buying
