It's been a long long time since I've updated this thread! It's a long one
So the RTS clutch is going well so far, it's done over 12k miles now and hasn't skipped a beat!
Made some slight adjustments to the tune in the summer and made 324bhp and 455nm, added a decent cold air feed which picks up air from the undertray and feeds the air just under the filter, very fiddly job to do but has been working well!
Been having loads of trouble with the map sensor too ever since the wires were broke from thermostat change, the car hasn't ran the same since, got really dodgy wires and joiners in place but it's really not happy so the car will eventually go to a decent autospark to sort.
Had to replace the DV too as when I was having really bad map sensor issues at one point ( car completely cutting boost ) it turns out it was knackered, here's how I found that lol.
Also I got round to fitting a subwoofer and amplifier to the stock headunit! Sounds really good to say it's running on stock headunit and honestly wish I did it as soon as I got the car, one of my favourite mods! ( No pics yet however it was a £40 special from Facebook marketplace )
Also changed all 4 tyres as mine were getting to their limit, went for the Goodyear eagle F1 supersport and there brilliant, a pretty noticeable difference from the eagle F1 as3 I had on before.
Within that same week the discs and pads needed replacing at the front so I got some mtec J hook front discs (stayed with 345mm as opposed to lighter 340mm) and some ebc redstuff pads, the braking now is brilliant for the stock caliper so very impressed with those, plus they look cool!
About a week or so after went to Santa Pod with
@Jamesw0720 which was brilliant, think the best time was around 14secs at just under 104mph, battling the wheelspin and getting a decent launch was hard though, 60ft times were consistently around 2.5 sec
After a decent summer I serviced it all again and changed the cam follower again too, there was barely any wear at all but better safe than sorry!
And also picked up a hpfp protector from creation motorsports in red just to bling up the engine bay a little.
For Christmas I used my pennies to get an RCD360 pro, always fancied a headunit upgrade just never really gotten around to it, unfortunately it's crap, sound quality is much worse than the stock unit, android auto is buggy, the unit freezes up and all together just not a great experience for a £260 head unit so going to send that back and get a half decent android unit. In the process of having the interior trim wrapped in gloss black and have the FL heater controls to go in which hopefully coupled with the headunit should modernise the interior a little.
Anyway now unfortunately the car is a little poorly, the injectors aren't happy so I have put the car in lockdown for now ? and I need to save up for a set of new injectors with the metal filter baskets, also picked up an RS4 fprv to go in when I do the injectors and I'll probably check and replace the spark plugs too just for the sake of it.
Still got a few plans for it this year ( one of my plans will be to clean it don't worry
) and it's a decent list so hoping I can do all the bits I want to do this year and hopefully this Corona goes away so we can get back to having some meetups!
