How does the material stand up to weathering? I know you say they are as strong but will they get brittle or discolour are all?
Hey mate the material stands up to weather just fine. The prototype material not as that is just PLA. But you use it for prototyping because its cheap and easy to modify.
The production material is PET based plastic but its a hybrid material that also has carbon fiber/composite in. The material maintains 100% rigidity and structural integrity till 120 degrees C. Internal engine bay temps dont even get that high.
The color doesn't fade either as it's resilient against UV etc.
I've done a ton of research and testing with different materials and for this specific part, this is the best material for the job without making the cost of manufacturing skyrocket.
Other parts might be other materials as it depends on what properties each part needs to have. For example a silicone hose needs to be flexible and heat resistant. A grill needs to be weather resistant and strong.
Sent from my RMX1993 using Tapatalk
