So I thought I would use this to remind myself of what has been done thus far, what needs to be done and what is to come.
I'll try and put dates for reference
2012 - All 4 shocks replaced, both rear springs and front wheel bearings
2012 - Water pump & cambelt replaced, gearbox oil changed, sump removed to retrieve bits of dip stick tube, new dip stick tube
2012 - Partial N249 delete, some hoses replaced with silicon ones , cold side side dv kit fitted
2014- 2018 - Not under my ownership.
2018 - Full N249 delete, Bailey dv fitted, cambelt and water pump replaced
2018 - Cone filter , tip and heat shield fitted
2019 - All 4 brake disks replaced with MTEC J groove and EBC Green stuff pads, both rear calipers replaced, front calipers rebuilt
Parts I have but not yet fitted
2019 - FMIC, rear anti roll bar , various polybushe's (must check to see what I do have)
Parts to buy/investigate
2019 - Oil cooler, braided brake lines, dog bone, exhaust
Would also like to tidy up the body as its a bit battered.....actually both mine and the car !!
2019 - Both front and rear strut bars fitted
