Damo H
4,715
2,820
Car Length In Front
So in my last Leon, the inner door shut got scratched by either little feet or my wife with the car seat.
So now my daughter wants to climb in herself I decided I’d put something on to protect the paintwork. Anyway had a play with some samples @paddy6789 had bought and created something that is probably too good to go where I’ve put it. So going to order some more (if only to give @paddy6789 some samples back) and make something for the exterior.
Apologies for the dirty car...
ciaranmcw
30
Someone linked these AliExpress Logo lights a few weeks ago and they are great.
However I am having issues applying them to the Hard Plastic on the inner door - the sticky pieces they came with are not great, especially the smaller one for the magnet.
Any ideas to stick them but also easily remove at a later stage if needed?
Reactions: louiskopite
sebastalian
62
13
Manchester
Hi,
Do you have a link for those logo on AliExpress?
Deleted member 103408
Fitted stop start memory module, very happy with the new setup, all I need now is the long coding to turn off the yellow light
It remembers where the stop start button was (On Off) when you turn the car off. So if you turn it off it stays off but unlike the coding solution you can just push the button and turn it back on again.
Kothaex
133
12
Ah ok thanks mate.
Just out of interest why do people dislike/turn off stop start? To me it just seems helpful and entirely unintrusive, but the Cupra is my first real car and first car with it so I'm lacking experience.
My understanding is the Cupra R now has this function as part of the build.
Stop Start has a place (I use it when going into big cities) but for day to day use it is just a pain. What the module does is turn the switch into a switch (simple on off) and it does not go back to the default mode (on) each time you turn the ignition off.
Titchy
519
208
Buckinghamshire
Is it a Vag group part or 3rd party?
Mine is 3rd party, you can build you own DV52 of the VCDS/OBD11 Forums put up instruction on how to build you own (I have posted a link to it in the past).
However as i say I think the new Cupra R has this ability but no idea how VAG have made it work.
Deano j1971
586
632
Got some new front Treads today obviously it had to be ps4's, noticed the difference straight away. Only downside I had argument with the manager at F1 auto center for not putting my gator rims back on the alloys.
Sent from my COR-L29 using Tapatalk
Legojon
I only wanted a remap
5,311
2,741
Um, so he didn't put them back on in the end?
