Fox wheels? Surely they are a good chunk heavier than the Ultraleggera?What colour low key alloy should I put on today and by the way white means you can have more choices of wheel colour.
1.2kg is not to bad under the circumstances!Heavier but a lot cheaper, might swap them over in years to come but for now I can live with the extra weight but stronger (for the track) rubber.
What offset are your ultraleggeras, and the new fox wheels?I did not think so, what I should have done was get the weight for the new rubber vs the PS4S but I was off to the track so needed it sorted quickly.
Just thought are they 8.5” width though or 8” like the standard wheels. Was thinking they sit very nice, but 6mm difference from stock doesn’t look that much different.
Hub should be the same even with the BBK, unless you got the bells with a built in spacer. Your added front camber would bring it in if anything.8X19 5X112 ET45 but dont forget i have different suspension and Revo Big Break kit so I expect that pushes me out a bit.
Don't disagree with what you are saying, maybe its because I am down so low but I would not want to go any further out than I am currently as i would get rubbing.
Mystery Blue
White has had its day.
Should be back to ford transits only
