Colour help !! Please post pictures of your leon should I get the red or the white ?
Which colour looks the best ?
  • Total voters
    45
Deleted member 103408
Heavier but a lot cheaper, might swap them over in years to come but for now I can live with the extra weight but stronger (for the track) rubber.
index.php
Sticklebricks
28
18
United Kingdom
I've toyed with the idea of getting Kambr 250Z alloys and sticking Oz caps on them as they are virtually identical to the Oz Ultraleggera as I'm cheap like that lol. Have you took a photo of the Fox FX004 on your motor yet?
Damo H
4,715
2,820
Car Length In Front
index.php
1.2kg is not to bad under the circumstances!
I keep considering wheels for mine, but then I do like the unique wheels (well if you ignore all the R’s and carbons lol).
The wheels I fancy would probably be heavier though. OZ Superturismo GT.
So maybjust ger spacers.
Is anyone running 15mm at the front? Wanted 10mm but with the hub they maybe to much of an issue.
I did not think so, what I should have done was get the weight for the new rubber vs the PS4S but I was off to the track so needed it sorted quickly.
Reactions: Damo H
r3d
56
33
My desire red one is coming next week.. but if i could change now i would choose magnetic gray.
Here is a pic of the desire red fr (i am kind of still hoping that the cupra color is a bit different than the fr one). It is just not convincing enough in my opinion and i paid extra 150 euros for it.
Woodygo
135
43
Birmingham
White is nice mate
8X19 5X112 ET45 but dont forget i have different suspension and Revo Big Break kit so I expect that pushes me out a bit.
Reactions: Damo H
Damo H
4,715
2,820
Car Length In Front
Hub should be the same even with the BBK, unless you got the bells with a built in spacer. Your added front camber would bring it in if anything.
Looks like 6mm spacer should be enough to get the stance I’m after then.
Don't disagree with what you are saying, maybe its because I am down so low but I would not want to go any further out than I am currently as i would get rubbing.
Damo H
4,715
2,820
Car Length In Front
Going to get the 034 Motorsport top mounts with whatever suspension I go with to add the extra camber, so should bring it in a bit.
But think I’ll save for an exhaust first.
