You were able to update your navi once with OBD11?
Can I add speed camera warning to my system? All I know is I have a 2016 normal media so no DVD but is the bigger screen with Full link, I can use waz but is it possible to add it to my standard set up ?
No I have the Mib2 High and my messing behind the scenes in the developers menu by editing the upload file caused an SVM. That I corrected.
Then a year latter I decided to have another go being persistant. Whilst in June or July 2017 I documented how you could update everything other than the Navdb directory. The upload file is signed so you cant edit that. Next attempt was to edit the contents of the uploaded file. These are signed as well with an "ECU signature". You can read and edit these with a Hex editor. Again the same level of security. Whilst the upload file you can check how the signature works with the public keys available I didn't check how which elements the ECU signature used but it's going to be similar. I wondered whether you could adjust some parts of that to make it look like what was installed. I got new error messages up and it's those that triggered an SVM this time round.
Answer to that no, it's all nicely locked down. Mib1 and Mib2 for the Navigation Plus are similar why they use the same upload files. Some Mib1 units were enabled for several sets of maps. I know Mib2 years you can load up historic years, go forwards and you get locked out till you reinstall the release the unit came with or before.
Wallone who posts up here had his unit turned into a retrofit. Going down that route now although concerning that alot of settings are held in the 5F unit including Top View calibration. If they get wiped out alot of data to re enter by hand. Obdeleven doesnt have a restore function so whilst you need to backup the 5F unit if you embark on this route just in case the guys doing it dont back up and restore the contents if they get deleted in the process. It's a high risk route.
It's got to have built in nav to use the ones I covered in here. Yours doesn't I reckon. For info for people that do following the debacle of VW POI upload site.
https://forums.seatcupra.net/index....f-woe-vw-pulled-the-update-site-again.444799/
The speed camera database people also have their own apps that people use e.g. pocket GPS World etc. Probably what you want if you don't want to use the Waz ones.
Then it is the link if you want to upload speed cameras and your own Poi's. I find the latter very useful since it makes the sat nav look like a regular one with your saved destinations shown on the map. It's also a good way to get accurate map coordinates in.Mine has factory built in 3d nav and 8" screen with Apple and Android link ?
Too much risk and fiddle. We are going to wait for another breakthrough...
Ok thanks and is it easy and how would I go about it ? Sorry I'm.not the best with this kind of stuff.
That's what I'm waiting for.You know the season of new Mib2 Standard and Mib1 / 2 High maps is on us . We're looking for ECE 2019. They lay about on servers ready to be given their official link. Can't see them yet thou. November each year and June.
