Howdy! I picked up my new Cupra R a few days ago and I want to keep a build thread for myself but for others also to see what their views are and any recommendations/improvements
Here she is:
Completed a few coding mods so far:
Here she is:
- Enabled Alarm Chirp with Lock/Unlock
- Auto folding mirrors with lock
- Auto fan speed display with Air Con
- Disabled open door alarm
- 5 flash 1 touch indicators
- Linear throttle setting
- Disabled sound actuator
- Speed Camera's added to Nav system (with thanks to @Damo H)
- Mirrors to unfold when ignition on
- Gas boot struts
- Gas bonnet struts
- Strut brace UK front brace fitted
- RacingLine engine dressing parts (coolant cap, dipstick, oil filler cap, brake fluid cap, washer bottle cap)
- RacingLine Fuel Filler cap
- 4G WiFi dongle hardwired in
- Dash cam hardwired in and connected to cloud
- Custom Drivers Footrest
- Custom Passenger light plate
- Autowatch Cat 5 Tracker
- Autowatch Ghost Immobilser
- RacingLine Dogbone mount
- RacingLine R600 Underhose
- RacingLine Oil Cooler
- RacingLine Oil Management
- RacingLine R600 Intake
- AutoTech High Pressure Fuel Pump
- Scorpion Sports Cat Downpipe
- RacingLine Intercooler
- RacingLine Stage 3 Hybrid Turbo
- RacingLine OEM+ Stage 3 Software
- Audi RS7 Spark Plugs
- Audi RS3 Coil Packs
- Audi RS3 Brake Ducts
- RacingLine Lowering Springs
- VAGSport Intake Hose
- RTS Twin Friction Clutch
- Leyo Charge Pipes
- GFB DVX Blow off Valve
- Remus Resonated Cat Back System with 4" Slash cut chrome tips
- BAF Rear Brace
- Diesel Geeks Stigma Quick Shifter kit
- Virtual Cockpit upgrade
- Funk Motorsport Turbo Blanket
- Footwell lights to change with the door cards
- RacingLine Upper Transmission Mount
- Upgraded water pump housing
- RacingLine Braided Brake Lines
- ECS Bleeder Block
- Braided Clutch Line
- RTS Paddle Clutch
- RacingLine Dampers
- RacingLine Drop Links
- RacingLine Stage 3 Big Brake Kit
- DO88 Coolant Hoses (Black)
- DO88 Charge Pipe Kit
- DO88 Enlarged Muffler Delete
- Fluidamp Crank Pulley + new belt
- 4" Intake Hose and larger R600 filter
- RacingLine Subframe Alignment Kit
- 034 Motorsport Rear Anti Roll Bar
- 034 Motorsport Rear Sway Bar Links
- Wireless Apple CarPlay
- Wireless Charging
