Okay... So as requested... Process and Products used.
Full Exterior Detail Process
Wet Wash
Wet Rinse - Open hose flooding paintwork
Snow Foam (Obsession Wax Snow Foam) Dwell for 5 mins
Power Washer Rinse
2 Bucket wash with grit guards and 2 wool mits - One for rooff and windows one for lower parts doors bumpers etc)
Power Washer Rinse
Fallout Remover (Obsession wax bleeding fall out remover)
Power Washer Rinse
Tar Remover (Obsession wax Tar / Glue remover) - Might need some agitating with a microfibre
Power washer rinse
Clay Bar - Using G3 speed detailer as a lubricant, meguairs clay bar
Power washer rinse
Wheels - for a full clean id take the wheels off, but use obsession wax bleeding fall out remover
Power washer rinse the wheels
Dry using a prestige car care "big yellow" frying towel
Dry Clean
I use a DA to machine polish
Meguairs compund - 2ft sq sections at a time using high lumen light to check correction / swirl removal.
Meguars Polish - As above
Obsession wax Phantom V2 - Applied using a damp pad small overlapping circles allow to haze
Single wipe removal using soft mircrofibre - I dont "buff" the wax, i find that a single wipe over is enough to remove the wax and leave a mirror finish and great protection.
I also have a selection of round brushes for door shuts, window seals etc.
Depending on the damage to the paint it has taken me 14hrs just to do the outside of a car, but I get a good finish on my cars in around 7, once a year is all i need to do them really as maintenance washes are done with the above method (excluding the dry wash process, claying etc) but means I do very little damage, i'll reapply wax every 2-3 months when the beading starts to fall away.
