The electronic handbrake is taking some getting used to though!
Well I pranged my car today in the car park. Thought I'd done a great job squeezing out of the car park, only to find when I got out this mess...
Bad start to the week...
I know that feeling - Still don't trust mine
On the day I picked my car up, I tried to use the electric handbrake as I would a manual one. It wasn't great and I was thinking I had made a big mistake getting rid of the Cupra 280 with a manual handbrake and buying the 300. However, I then discovered the auto setting (note to self, pay attention during the car handover) and that is what I have used ever since. You pretty much forget about the hand brake, the car just does it for you and I have found it works really well.I have never driven a car with an electronic handbrake! Or do people jsut keep it on auto most of the time?
It doesn't apply the handbrake, just holds it on the brake for you. If you check out reflections etc your brake lights will still be on. A pull on the lever and the handbrake is applied and brake lights go off.On the day I picked my car up, I tried to use the electric handbrake as I would a manual one. It wasn't great and I was thinking I had made a big mistake getting rid of the Cupra 280 with a manual handbrake and buying the 300. However, I then discovered the auto setting (note to self, pay attention during the car handover) and that is what I have used ever since. You pretty much forget about the hand brake, the car just does it for you and I have found it works really well.
Yesterday the lady got a clean inside and out, and I fitted my new wiper blades.
Also just swapped out the useless reverse bulb with a brighter LED one .
Next task is to remove the red filter from the rear fog and activate that as a second reverse light.
