My last car, Toyota Auris, had auto lights OEM, and these never came on in these condition. I had to always manually switch on lights... That didn't bother me though.....
Lol, I'll post some pics if I go down that route...Some cars I had with OEM auto lights have come on some have not. If it was really dark during the day my Corsa's would switch on.
Will be interested to see which route you go down, if it could be fitted in the grill with a small hole would look quite OEM. Don't think I would be brave enough to drill a hole in the centre speaker grill
Just got the nod that mines in the post. Sweet!I decided not to order the £250 comfort pack as only wanted auto lights and ACC in terms of options.
Realised I could buy an auto light kit off eBay for £25 for a Golf mk7/Octavia 2015, which we all know are the same as the MKIII Leon
https://www.ebay.co.uk/itm/Chrome-A...e=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
It really was a 10 min fit, only part I was not keen about was the light sensor position in the instructions.
The actual switch removal is a simple push in twist and then pull out. Feed wire and sensor through trim. Wait a few hours for the sensor to build up some charge (as would not work initially) and I then had fully operating auto lights
New switch
Recommended position via instructions
The position I moved it to and tested and gives you an idea of the size of the sensor
One thing I noticed from your install pic is the background lightning for the light symbols is white...
Mines red....
I take it this is because the mod unit is from a different breed of car.......
Not a dealer breaker for me, just curious......
Maybe it's as easy to install auto wipers too. Stalks are readily available, maybe just needs another sensor...
Sent from my Pixel 2 XL using Tapatalk
Installed mine yesterday. Was an absolute **** to put the side plastic panel/trim back on. I kept bending the little plastic connectors trying to re-attach them. Also a metal connector from one of them pinged off somewhere inside, never to be seen again haha!
Other than that, 10 minute job. Works, pretty happy!
Mine was rather stiff to get off, but went back on easier with a firm thud
Where do you start? At the bottom or top? It came with a trim removal tool
I’m struggling to get the original switch out, don’t want to break the original. How do you do it? I did read some instructions somewhere but can’t find them again. TIA
