Did that dent just pop out?
Notice any difference?Yesterday i had the inlet valves walnut blasted. They have come out immaculate. Also had the injectors cleaned.
Was it much effort changing the speakers? Would you say its worth doingInstalled SatNav and new speakers
forged engine,revo intake,3" TBE r tech stage 2 -323bhp 333ftlb build thead: http://www.seatcupra.net/forums/showthread.php?t=440348
Yesterday I drilled into the little white motor box in the passenger door so I no longer have to open the door from the inside... Great guide on here and within a few hours it's now up and running...
Saving £250 a door... 2 Doors left.
I was in the mind if I could save £250 I'd give it a go and if it died I'd get a new one... I have a rear door to do.I was going to do this as both my rear doors would only open from the inside. I started wondering how long this fix would last and ended up replacing both with oem locks
As the video on the guide is only for a front door when I get round to doing the rears this weekend I can take pictures of the latches and motor if that helps...My driver side rear is starting to play up, might have to give this a go as well
