What did you and your MK2 do today?
RnPnJ
110
Yesterday i had the inlet valves walnut blasted. They have come out immaculate. Also had the injectors cleaned.
Leeoncupra
764
191
Halesowen
Fitted gas bonnet strut kit and boost gauge
Quite pleased just need to wire up the gauge to light up
forged engine,revo intake,3" TBE r tech stage 2 -323bhp 333ftlb build thead: http://www.seatcupra.net/forums/showthread.php?t=440348
Because_Leon
15
Not a huge amount of effort. I found a kit on good old eBay with vibe speakers..
£45 for the front and another £45 for the rears.
Biggest issue is fitting the door cards in the cold!
I would recommend it. Well worth the money!
RnPnJ
110
Ordered a full BCS system. Gave her an oil change after changing cam follower. Used liquimoly oil very impressed so far.
Ordered some rear discs and pads using ECP promo code
Jimbobcook
6,160
2,540
Yesterday I drilled into the little white motor box in the passenger door so I no longer have to open the door from the inside... Great guide on here and within a few hours it's now up and running...
Saving £250 a door... 2 Doors left.
RnPnJ
110
I was going to do this as both my rear doors would only open from the inside. I started wondering how long this fix would last and ended up replacing both with oem locks
Jimbobcook
6,160
2,540
I was in the mind if I could save £250 I'd give it a go and if it died I'd get a new one... I have a rear door to do.
Took me about 10 minutes after doing it once. Just needed to be careful with the drill lol
Currently Driving - SEAT Leon Mk2 Cupra R 2010
Previous Car - SEAT Leon Mk2 FR 2007
Jimbobcook
6,160
2,540
My driver side rear is starting to play up, might have to give this a go as well
As the video on the guide is only for a front door when I get round to doing the rears this weekend I can take pictures of the latches and motor if that helps...
Jimbobcook
6,160
2,540
Nice eventful day, some little bits done...
Updated the RNS310 to 0351 from 0231
Fixed another dodgy door motor for remote locking (drill + wd40 = working door)
Cleaned out the inside and found some mounts for my samurai umbrella to be fitted in the boot haha
Jimbobcook
6,160
2,540
You win haha
