So it went in and when I went to pick it up I was told it never went on the rollers as it was running lean so would melt the pistons....I needed to buy bigger injectors as mine (0280155897) were only 217cc and it needs 310cc with the KO3S.* So I said I had the injectors off the car with the ko3s and when I did a part number search they were compatible with the APP engine.....he then told me without a remap they would melt my pistons. So I asked him to check part number of the other injectors....which he did......using*eBay.....and used*eBay*to show specs of mine....both showing 217cc....so he then went go the draw to get his aum injectors that would solve my
problem with a remap....guess what.....same part number as my spare injectors (0280156061).....which eBay told him were only 217cc!!! He then looked elsewhere and everywhere said both sets of injectors were 310cc...so will be fine with the ko3s...They started going on about the fuel pump being the issue then. Im lost now as to what to do. They showed me VAG-COM block 032 showing correction of 1.9% on idle and just over 20% under load, I haven't had chance to do my own log and they have left the N75 unplugged to keep boost down to save my pistons from melting.....it all seems a bit too much like they really wanted it in to get mapped so I don't know if they are that great. I have got a fuel pump to pop in it and see if that makes any difference to the fuel correction but I'm not hopeful
Sent from my SM-G930F using Tapatalk
