Ok so I have had turbo issues with my car (not boosting then making loud noises, then finally chucking oil out the exhaust) so I swapped out the KO3 for a KO3S with new seals/gaskets. Also fitted a boost gauge, which moves (although does seem to jump around a lot rather than smoothly going up, not sure if thats normal), but the car just doesn't feel quick on acceleration. The car has had the turbo fault from the day I got it so I have nothing to compare the power/acceleration to other than my old MK4 Golf 150bhp GTTDI (being diesel the turbo kick is obviously more than stock petrol due to massive torque). The N249 Solenoid does not 'Click' when running VAG-COM output tests so feel this is probably faulty. Any ideas what else could cause the car to feel a bit 'meh'?
Also, not sure if this is relevent but also from the day I got it, and still even with different MAF, the T/C light comes on whilst driving (not all the time but most of the time) and stays on until you turn the ignition off.
