What did you and your MK2 do today?
G4reth
FR PD170
Dec 4, 2011
393
Middlesbrough
The air vent surrounds? A very small flat head screwdriver.
See on the below pic. The clips the top two are closer together than the bottom. Just slide the screwdriver down the side and flick the clip up and gently pull. Do one side at a time.
Quadrablast
209
Stockholm, Sweden
Today i changed my camfollower, pcv-valve and mounted my sweet turbo/manifold Heatshield from CTS Turbo. Feels like a must have when i mount my induction kit..
Rob_Talisman
MKII CR FR 170 FL Stage 2
Sep 2, 2013
811
North East
Just had my insurance renewal come thru from Adrian Flux £475 think its a bit steep for my age...... who do people use/recommend for modded cars?
Dan FR
Meth addict. Stage 2+ Yo!
Nov 14, 2013
1,794
8
Caerdydd
With mods, you can also try Grenlight, Sky, Chris Knott, Prestige
Get quotes, then ring Flux back to cancel on the basis that you have found a cheaper quote from one of the above.... See what they say.
I went with Sky after playing them off against Flux, who wouldn't go any lower..... Couldn't go with Greenlight as one of my named drivers had less than 3 years driving experience at the time, so they wouldn't insure me, and Chris Knott would only insure my postcode if i had a driveway or off road parking, which i don't
Rob_Talisman
Sep 2, 2013
811
North East
cheers Dan will do.
done the meerkat scouting which was ammusing, came up with two quotes, one at £2500 and the second at £36000....
i had to double check id put in the right detials... and i had...
richicupra
1,823
9
New rear passenger door module fitted. Pretty straightforward, just a massive pain to remove everything.
locky
1,073
North East
Nice one. Ive not had the pleasure of removing door cards but it seems a four hand job from what I read!
So I finally got round to trying the stubby ariel Craig kindly gave me.
Got fairly rubbish reception anyway so wasnt holding my breath.
The standard ariel unscrewed and pulled out the retaining on the first attempt.
Fitted the stubby and the radio reception was the same.
Removed the stubby leaving it totally ariel-less and the reception was the same!!
Put the standard back in, reception the same.
Guess what, now I cannot remove the standard ariel no matter what I try!!
confused lol.
