I'm actually from daaaan saaaaf, but 14 years in the toon and things like 'wor lass' just seem to pop out my mouth now and then![]()
you have turned foreign like the rest of them
Need to save for a new clutch, ffs![]()
Oh no! How bad is it?
Budget for a flywheel too.Need to save for a new clutch, ffs![]()
It's pretty bad, definitely slipping in 4/5/6th gears lol
I thought mine was slipping, but is only very occasionally and only at 4k ish rpm, it holds strong even in high gears at low speeds if I boot it (only did this to check for slip, I know this will kill the clutch very quickly!). It quite strange and happened last year, was then fine all year and now has appeared again. Seems to be seasonal haha
I thought mine was slipping, but is only very slight, very occasional and only at 4k ish rpm, it holds strong even in high gears at low speeds if I boot it (only did this to check for slip, I know this will kill the clutch very quickly!). It quite strange and happened last year, was then fine all year and now has appeared again. Seems to be seasonal haha
Sent from my G3 using Tuppytalk
My local garage who replaced the clutch sourced mine from their parts supplier, probably best to get quotes from a few places, think i paid around 240 for the standard dmfYeah, I'll get the whole lot done at the same time. Cheapest place for a DMF?
Carpartsforless using discount code Saveme75... Mine was sub £200 for an LUK DMF, whole clutch kit was only a smidge over £300
I thought that said "carpetsforless"...... I need a drinkwhat stage of tune are you running with the standard clutch as i would like to go to stage 2plus and remain using a dmf.
I thought that said "carpetsforless"...... I need a drink![]()
I'm on a baby K03 so different ball game to the Cupra. Been running stage 2 but upgraded to 2+ this afternoon
