Leon mk1 1.8t decat pipe
BurnyZS
112
Basically my downpipe has snapped off on the welds right by the flexi/turbo so I'm looking at decat pipes rather than a new downpipe/cat.
Is a mk4 golf gti 1.8t decat pipe the same as a leon mk1 1.8t? I'm thinking yes but need confirmation first please.
nd-photo.nl
3,668
22
The Netherlands
www.nd-photo.nl
Yes should fit without issue:
http://www.ebay.co.uk/itm/350572858297
Fits:
AUDI A3 1.8T 110KW/150 ENGINE CODE AUM 05/2000 - 06/2003 WILL NOT FIT QUATTRO MODELS.
AUDI A3 1.8T 132KW/180 ENGINE CODE AUQ 05/2000 - 06/2003 WILL NOT FIT QUATTRO MODELS.
SEAT LEON 1.8T 132KW/180 ENGINE CODE AUQ 09/2000 - 03/2004 WILL NOT FIT CUPRA MODELS.
SEAT TOLEDO 132KW/180 ENGINE CODE AUQ 09/2000 - 03/2004.
SKODA OCTAVIA 110KW/150 ENGINE CODE AUM 08/2000 - 04/2003 WILL NOT FIT RS MODELS.
SKODA OCTAVIA 132KW/180 ENGINE CODE AUQ 01/2001 - 04/2003 WILL NOT FIT RS MODELS.
VW BORA 110KW/150 ENGINE CODE AUM 09/2000 - 03/2004.
VW BORA 132KW/180 ENGINE CODE AUQ 05/2002 - 03/2004.
VW GOLF MK4 110KW/150 ENGINE CODE AUM 09/2000 - 03/2004.
VW GOLF MK4 132KW/180 ENGINE CODE AUQ 06/2001 - 03/2004.
VW NEW BEETLE 110KW/150 ENGINE CODE AWU 06/2002 - 03/2004.
BurnyZS
112
There is 2 places for the lambdas. Fitted it today and took all my boost pipes off while I was there to check for a boost leak which I have and iv found there is oil in the intercooler which makes sense so I'm going to start prepping for new turbo. Is it the k03s on 1.8t Leon ? Iv ordered gaskets for oil feed/return coolant feed/return washers. All manifold and turbo gaskets. Anything else il need bar the turbo?
Azza_
526
South Shields
a small amount of oil in the intercooler pipe work is fine, specially if its the first time the pipes have been off.
i wouldnt go racing out to buy a turbo. clean the pipework and re-check in a couple month
BurnyZS
112
The oil was in the intercooler. As I took the pancake pipe off the inter cooler pushed back and it all dripped out into my eyes and hair lol
Azza_
526
South Shields
yeah there always is, the seals weep slightly, id clean and check again when you can waste of money splashing out on a turbo for no reason
BurnyZS
112
Hmm ok il give it a while. Iv ordered all gaskets and washers so ain't wasted too much money yet. Iv been told the turbo could be on its way out because I just loose all boost when the cars been running a while. On first start up its fine. Iv been looking for a boost leak bit can't find anything that's gonna make me have no boost whatsoever
nathan_20vt
365
Kings Lynn, Norfolk
Any good? Seems like a bargain. Just need the lambda spacer aswell yea? I'd be running mine with just the standard back box (removed centre box) hoping it won't be too loud
