Weight with Silicone pipes = 13.2 KG or 29lbs. Quite a lot in comparison to the S3 core but im hopeful the benefits will far outweigh the extra mass up front.
Also measured up the bolts, they are M6 (10 mm hex) x 16mm, 9 needed. £1.50 delivered on eBay although i'll be picking mine up with washers & spring washers from a local engineer supplier
