I have an intermittent issue with my rear parking sensors. Been working fine for ages and all or a sudden they keep going into error mode. When I have had the car plugged in once before there were no error codes for this issue, which leads me to my first question? would sensor errors report error codes to the ECU as a friend of mine told me that even though the car came as standard with the sensors they would have likely been retro fitted and not by the factory and because of this they don't report to the ECU.
My second question is if that is the case how would I determine which sensor is causing th error? I assume by trial and error.
Thirdly I believe it is a bumper off job to access them and you can't get away with the inner trim that the sensors are housed in being removed?
Is the bumper off an easy job?
I don't own a workshop manual although thinking of buying an ebay one, any good?
Any help on this matter would be a great help!
