What did you and your MK2 do today?
Jarre
5,365
11
Stockton-On-Tees
Depends how low you wanna go I guess. If you would only put JOMS on at a similar stance to what the sportlines would give then id just go for sport lines. I imagine they'd be more comfortable, but I've not been in a car with JOMS! Mines on AP coilovers and I'm really happy with them now :)
Shawn-C-87
356
Edinburgh
Has anyone fitted this to there 2.0tdi 170cr leon mk2. Just wanted to make sure it was the proper one for me. Also doesn't cause any problems with the DPF?
shnazzle
Glass-Half-Full Member
Sep 9, 2011
3,483
Northumberland
There is one "proper" intake for your diesel and SEAT has already put it on for you :)
Save your pennies and get some nice lowering springs or something :)
Shawn-C-87
356
Edinburgh
Haha cheers for that mate, I'm also looking at fitting sportlines just concerned as I have the btcc kit and a front splitter so dropping it 45-50mm will surely make it hti every bump??
shnazzle
Sep 9, 2011
3,483
Northumberland
Haha. Only if you go over them like a tool. But yes you'll have to take it a bit easy. Mind. Plenty of space
Jarre
5,365
11
Stockton-On-Tees
You won't hit any bumps with sport lines! I don't hit that many and my coil overs are low and I have a front splitter! I don't catch the splitter, I catch the middle of the car when going over speed bumps sometimes. Sportlines are quite a bit higher than my coil overs too :)
shnazzle
Sep 9, 2011
3,483
Northumberland
But you don't have btcc coolness. Fail.
Benzy
1,220
You won't have any issues mate. The splitters were designed to lose minimal height. :)
Ye you should be fine Shawn. When Kev and I got together to design/build the splitter for the btcc kit we worked with ground clearance being a key point. So instead of making something to strap onto the bottom, we made something to mould up into the base of the bumper. Thus, from the front it looks a lot lower but you are actually only loosing 1.5-2mm of ground clearance.
Hope that helps buddy
Shawn-C-87
356
Edinburgh
Cheers benzy. Puts my mind at ease because the last thing I wanted to do was leave my bumper at a speed bump.
