Seat Sport Cupra brake caliper info
k123
I finally got them finished but my hands are still buzzing from wielding a 3kg lump hammer for a weekend!
First off, you'll need a 4mm punch. The Facom one won't do..it's too long and I bent one very quickly. It needs to be only a couple of inches long.
The longer punch is good for once you have it moving and pushing the pin through some more.
Read all the posts and get yourself some supplies in. Pins are a definite MUST have.
Photo for identification:
Undo the bridge bolts with a hex socket.
Then start on the pins, knocking them out from the narrow end of the pin / outside edge of the caliper.
I got 1 out of the 4 to come out like this.....even though I'd taken the Caliper off the car and had it on the bench/floor!
So got the hacksaw out...
Using a full hacksaw and just the blade (no handle) I found I could cut the pins into several sections to remove the pads or disc etc to get the Caliper removed from the car.
I could then attack the pins from the outside of the caliper, managing to get the narrow ends pushed through eventually.
The other end I was knocking into the middle of the Caliper without much luck.
I then needed to drill these out. using a 4, maybe 5mm drill bit it made a surprisingly easy job, even with a basic power drill. It seemed to follow the pin and leave the soft Aluminium caliper alone!
I was able to drill right through the centre, and then clobber the remaining outer rim of the pin with a 6 or 7mm punch, folding the metal in on it's self and out of the other end.
Finally, they're in pieces! :clap:
Now the corrosion.....
My pads wouldn't fit and by removing the shims which the pads run on it was clear to see there was more corrosion there.
The white stuff isn't good
You can see from this photo how the metal shims rise up as they go into the corner.....not good for getting the pads to fit!
Got there in the end but it was a couple of days job and MUCH MUCH more difficult than I expected :-o
Old bits left over....in desperate need of replacement!
Apr 13, 2011
1,971
hull
This is a usefull thread for anyone with a mk4 Cupra or mk5
Would it be possible to post up the part numbers of the. Items advised to buy when about to change brake pads ie
Retaining bolt
Pads
And anything else that commanly seizes and u end up needing when doing what should be just a simple brake pad change :)
titanium4d
wales
I'll be doing mine in the next week or so , will make sure I get new fitting kits :) , ill be changing the brake hoses for steel braided ones and dot5.1 so good to know the proper torque settings , thanks :)
Crumpyz
130
Basingstoke
Hey all I contacted AP not that long ago as I wanted to find out the torque settings and any retaining compound used as I am currently overhauling mine (didn't realize this post existed) :) They were brilliant and could not have been more helpful!
AP gave me different torque figures to the ones listed, so I thought I would share.
Caliper part numbers:- CP6607-8S0:SEA & CP6607-9S0:SEA
Retaining compound:- Loctite 620
This is actually a high temperature cylindrical retaining loctite used in assemblies...but AP obviously use it for bolts because of how it cures and it having a very high temperature resistance!
It is also near £30 for a 10ml bottle in the UK & delivery (which is very hard to locate, it seems to be easier to buy it from the US in 10ml form, but import charges will kill you, this company sells it http://www.midwayuk.com/Loctite-620-Retaining-Compound-10-ml) So as you can see it is worth its weight in gold...I was lucky as my work use it :)
NOTE:- !DO NOT LOCTITE M8 PAD RETAINING BOLTS AS THEY SCREW INTO A HELICOIL INSERT! Next time you would go to take them out you would most probably pull the helicoil insert out as well, which is a whole world of crap.
Torque Settings:-
• Caliper Mounting screws M12 = 68Nm
• Bridge bolts M10 = 68Nm
• Pad Retaining bolts M8 = 24Nm
• Wear Plate screws = 6Nm
• Bleed screws = 10Nm
It is key to remember that some of the screws/bolts are straight into cast ally (or billet not sure how the calipers are made), to which threads strip very easily, but can be saved by an insert tap and helicoil insert!
Hope that helps!
mjstokes85
Diesel Power
Nov 14, 2005
1,518
25
39
Long Eaton
I have been in touch with AP racing to try and blag some free pins etc. Unfortunately they won't send me anything free, BUT they have given me all the correct part numbers for the pins etc
Dear Sir
Caliper # CP6607-8S0:SEA & CP6607-9S0:SEA
AP Racing does supply Seat with pad pin kits , but if you don’t have a local Seat dealership close by or they are unable to obtain them for you, then you can order pins from one of our official distributors listed on:- www.apracing.com
If you are based in the UK try Circuit Supplies, they hold these pins in stock.
Pad retainer Pin # CP7600-109 (95mm long)
Pad anti-rattle clip # CP6607-124
(When refitting the pins smear the split collet with a light film of copper slip, that will help to reduce the effects of road salt corroding the steel collet into the alloy caliper body).
The disc and pads are Seat parts, but if you wish to improve the braking and also reduce pedal travel then change the pads to Ferodo DS2500: - APR pad set part # CP6600D50-DS2500. Circuit Supplies can supply these as well.
Regards
Peter Collen
I have emailed Circuit Supplies http://www.circuitsupplies.com/ap.htm and asked for a price on the anti rattle clips. The correct pins can be bought here - http://www.part-box.com/product_info...ducts_id=36555
Mr. F
What are the SEAT part numbers for the Calipers etc? Can't find it anywhere (somehow) and my garage needs them!
Crumpyz
130
Basingstoke
Caliper part numbers:-CP6607-8S0:SEA & CP6607-9S0:SEA
They are as above mate. If you read through the thread they are mentioned a few times.
Sent from my GT-I9505 using Tapatalk
Crumpyz
130
Basingstoke
No prob :) haha.
You can buy the calipers and parts through seat I believe but will probably cost you a leg and maybe part of your arm.
rsshawn
44
Just wanted to re-up this incase anyone is doing this soon.
Circuit Supplies still have these. The pins are £1.20-ish and the clips are a little over £3 each.
I haven't done mine yet, just collecting spares incase they are required. :whistle:
Badger
2,888
7
Newcastle, Staffs
If you have a Sport or FR model with 288mm Brakes, then you don't have to upgrade the hubs and will bolt on.
The pipes are 60mm longer - 6LL611701
I don't think the union bolt is different though, could be wrong.
