I LOL'd at the grammar / spell police...
Thanks for All the comments Guys, i really appreciate all the support on the forum... i would say if it wasn't for the forums i would have jacked the project in a while ago. Not now though i'm feeling positive
I've just come back from a fortnight working in Northern Ireland so not a lots happened - i did do some more painting before i went though....so here you go.
Mounted the remaining doors on the stand then flattened to primer down with 320 using a block.
It was a bit on in the day to start mixing paint so i spent a while rubbing down the rear spoiler delete (this is just to cover the gap above the rear window so to allow the airflow to flow to the new rear spoiler)
Ready for primer now -
The following day i mixed the paint up ( i have been over thinning the mixture to
help flow through the small SATA mini jet ) but i decided to try and stick to a maximum of 30% thinners.
The reason i've messing about with the mix a little is because the paint i've done already isn't really really hard yet (if i push my nail into the paint as hard as i can i can leave a tiny mark )
I stuck very exactly to the mixing ratio's which was 2:1 of paint / hardener but it said 10-30% of thinners - i tended to use more thinners as it helped me get a really good finish from the gun.
So i really struggled on with the paint and it came out "ok" some areas were quite orange peely.... it was quite hot on the day and i think my Speedy thinners were evaporating before the paint could run back into itself. So a tad dry in some parts.
One particularly orange orange peel
So knowing that i'd be wet sanding the car complete the polishing it up i wasn't that bothered.
A couple of weeks ago i decided to buy some stuff to check that the paint was going to work well wet sanding / cutting / polishing.
After a bit of research on Detailing world and a couple of suggestions of buying a good rotary, i chickened out and bought a DA.... after all i've never used one so it a better choice for a beginner (safer) although it'll take a lot longer to polish out sanding marks but as anybody will realise reading this i'm in no rush :lmfao:
So i bought -
A Meguiars G220 V2 with a Sonus SFX Polishing / Cutting Kit compromising of 4" & 6" (cut & polish) pads with various backplates & polish & Finishing compound.
Here's a link for anybody thats interested -
http://www.rollupandshine.com/meguiars-g220-v2-sonus-sfx-2-polish-kit-with-spot-pads-316-p.asp
I also ordered some stuff from Polished Bliss -
PB Soft Paint Polishing Kit
Meguiars Sanding Backing pad
Meguiars Water Spray Bottle
Meguiars Wash Mit
Meguiars Wash Bucket & grit guard
Meguiars Supreme Shine towel
Meguiars Ultimate Wash / Wax
3m Blue low tack tape
So after all this stuff came i had a quick go on one of the doors.
Then i discovered i didn't have any 1200 wet & dry so i wet sanded with some 3M 800 with plenty of water with a bit of soap in. This took the orange peel out quite quickly, i then went over it with some 2000 grade and then fired up the polisher for the first time.
As i was a bit cautious i used the stuff that came in the soft paints kit, and it works a treat.... although a little slow.
Then i finished of with the fine pad / polish stuff.
I then realised that there were still light sanding marks in the paint although the paint had come up ok, i obviously didn't spend long enough with the 2000 and long enough polishing. but it's a good learning experience.
Sanding marks -
So i decided to use just the 2000 grade to do an area of the door , the 2000 grade stuff is just cheap sh*te i bought from ebay and it showed.... but i cracked on and then got bored and decided to polish it up. It's going to need more wet sanding but i'm quite happy that with some work it'll be looking like orange glass !!!
So after my first experience / training myself with the DA i decided i needed some more good quality wet and dry so i put another order in with polished bliss. I also decided to get some wet & dry pads for the DA to
help with the cutting procedure.
So i bought some Mirka Abralon Discs of 1000-2000-3000-4000 grades in 2 sizes of 77mm and 150mm
I also bought some decent wet and dry - some Meguiars UniGrit 2000 & 3000 (sold out of the 1000 so i'll have to get some from somewhere else) and a litre of Meguiars Ultra-cut compound as i thought i'd need a sh*t load to do the whole car.
So after struggling with the actual painting of the doors i decided to stop messing around and just buy a bigger gun designed for High solid paints. After much research i found out that HVLP guns aren't that good for spraying Clearcoat / 2K as the HVLP can produce a drier coat / more orange peel.
After working with the SATA Minijet for so long i started to look at SATA's but i really couldn't justify spending £500 on a gun to paint a set of wings / bonnet and bumpers.
So i found loads of people who love the DeVilbiss guns, and to be fair there a fair bit cheaper than a SATA and come with various tips / nozzles to suit the type of work your doing.
So i bought a Devilbiss GTI PRO with a 1.3mm needle and a T2 cap.
Here's a bit of bunf from the website -
DeVilbiss GTI PRO Gravity Spray Gun
Our opinion - a very popular choice from large bodyshops to perfectionist hobbyists. Cutting edge technology with easy servicing and quick parts sourcing. A great choice.
Developed for busy professional painters needing the ultimate in quality finishes.
All new ergonomic gun body design.
New ultra high flow fluid tips provide superb versatility across a range of viscosities. Revolutionary air valve design gives smoother feel for even greater air and paint control for ease of fade-outs and blend-ins.
Simplified, user friendly components provide easy cleaning and maintenance (also shares many spares with it's sister mini gun, the SRi.)
PLEASE NOTE - there are four air caps to choose from that affect the way that the gun sprays. These are:
T2 - Faster flow gloss/lacquer
All round gloss / clearcoat gun.
Flow rate and fan pattern lend themselves towards a wetter application style.
Compliant trans-tech high transfer efficiency (but not HVLP)
Air consumption T2 (free air)12.4 CFM / 350 l/min
Fluid tip sizes available: 1.2, 1.3 and 1.4.
For 2K gloss / clear the 1.3 is by far the most popular choice & is recommended by the majority of paint manufacturers for their HS 2K products. (DuPont & Debeer -1.2)
This set-up is designed for Clear coats / 2k than require a good wet coat.
Pics -
Hopefully i'll give it a go in the next week or so, i "should" be off for a few days so i'll hopefully get the remaining two doors fitted and then start on the remaining parts to paint
Thanks for reading & any comments.
Cheers,
Graham.
