Exeo rear amplifier connections/pinout?
ExeoSteve
Hi,
Does anyone have the wiring chart or pinout for the audio amplifier that drives the Exeo rear speakers please? Audi sometimes used to put stickers on their audio systems with the wiring layout shown, but after half an hour stripping out my boot lining to get to the amp, I found that Seat didn't do the same.......
I suspect that the amp may have a subwoofer output built in (even on the non-Bose cars that don't have a sub fitted), as the bass of the rear speakers stops at 60Hz while the identical front speakers go down to 30Hz.
This looks like a cross-over is fitted in the amp with a separate subwoofer channel. If I can sort out the wiring, I hope to be able to post an update on how to fit a subwoofer to a non-Bose Exeo.....any input will be gratefully received!
Thanks, Steve.
Loonyjuice
Newbie
Dec 5, 2005
117
Warrington
I can't help you but I would be very interested to know how you get on. I've got a sub and bose amp, but haven't been able to work out what I'm doing with them. Having had them a year, they'll probably end up back on ebay!
kblackburn
94
holme/cumbria
Don't know if this will help
ws = white
sw = black
ro = red
br = brown
gn = green
bl = blue
gr = grey
li = purple
ge = yellow
or = orange
rs = pink
Radio, Amplifier, Rear left bass loudspeaker, Rear right bass loudspeaker, Rear left mid-range and treble loudspeaker, Rear right mid-range and treble loudspeaker, Internal microphone, Bass loudspeaker
R - Radio
R12 - Amplifier
R15 - Rear left bass loudspeaker
R17 - Rear right bass loudspeaker
R34 - Rear left mid-range and treble loudspeaker
R35 - Rear right mid-range and treble loudspeaker
R74 - Internal microphone
R100 - Bass loudspeaker
T17g - 17-pin connectorS01HXXX8X807#BTT17g
T20b - 20-pin connector, on left B-pillar
T20c - 20-pin connector, on right B-pillar
T32f - 32-pin connector
346 - Earth connection (audio), in dash panel wiring harness
* - Screening on connector housing
mightyevi5u
Same here, I don't actually have the parts to install but i'd seriously consider getting them if it meant sorting out the diabolical audio from the back speakers. It's the only thing that spoils an otherwise great car.
ilknur07
23
Dear all
Does anybody tell me which type of amplifier is used for seat exeo rear door speakers without bose system?
Any help would be appreciated
ilknur07
