andrewdask
Hey I'm from south america and this is my build thread. Started december 2011 finished june 2012. Now taking some new pics of the car and get the reflash fro REVO tomorrow, so here is it enjoy it changes will come! comments and questions are welcomed.
here is the original thread from VW.vortex not many comens lots of views.
http://forums.vwvortex.com/showthrea...3#post74801643
starts
Im moving my build thread up to here it will maybe have some more visits and questions.
original thread:
http://forums.vwvortex.com/showthread.php?5515147-Seat-leon-fr-k04-project
I haven’t find any good thread about a BWK04 but now its coming… im putting together in my Seat Leon FR mkII (K03 based car)… im trying to push all power hidden in this magnificent turbo out. Here are the actual mods of the car, and coming…
Photos coming later!
--ACTUALLY--
Engine
-FMIC Forge
-S3 up pipe
-Eurojet valve cover
-EVOMS 3” intake
-APR RSC 3” Turbo Back Exhaust
-Deleted PCV
-NGK Spark plugs
-R8 coils
-Custom catch can
-BSH engine mounts
-HPFP Autotech
-REVO stage 2+
-BSH boost tap
-Recent changed internals of gearbox (6spds manual 02Q)
-South-bench clutch stage 2 daily
Body
-Eibach Springs pro
-Upgraded sway bars
-Rear wheels spacers
In the car
-A/F AEM gauge
-Defi Boost Gauge
--COMING SOON--
-K04 turbo
-S3 injectors
-Neuspeed hi-flow discharge pipe
-BSH up pipe
-BSH 550Hp FMIC
-DevilSown Water meth stage 2+
-E-Boost 2 Turbosmart boost controller
-INA 1.8t Oil pump no balance shafts and Oil pan Baffled
-Fluidamper (not sure yet)
-IE 144x22 rods with riffle drilling and ARP 2000 bolts
-JE pistons 9.5:1 with tool steel wrist pins
-Main Stud Bolts ARP
-Ferrea valves kit OEM Diameter
-Peloquin’s LSD
-IMPORTANT ALL SEALS, GASKETS, SHIMS, ETC
-Big Brakes
-APR In tank fuel pump
-REVO STAGE ?? CUSTOM REPRO
Here i got some old photos of the car
my old forge intercooler
My actual engine bay !
im right now taking pictures of the pieces i got until now, post them later
Here are the pics of all i got until now
Old pod and Aem gauge
Old DV valve
Water-meth Kit
Head gasket, intake manifold gasket, Rod bearings and E-Boost2 with OSIR mount
Old fuel pump
New APR pump
Mounted
RODS PISTONS AND VALVES
BIG BRAKES
SOME MOTHNS AGO REBUILDING MY GEARBOX
PENDULUM MOUNT INSERT AND HEAD STUD BOLTS
INA BAFFLED OIL PAN, ADAPTATION FOR K04 OIL RETURN, MAIN CRANKSHAFT BEARINGS AND SEALS
I thought this never happened but here is my cam follower and piston shattered, and soon my camshaft scratched, but I have a new one from S3
Hey there people! I have been doing work! engine is out cams are off for valves, differential it's mounted and shots conning this or next week, here are some shot from my yesterday work
OEM wastegate Vs. Forge wastegate
A shot from Internet of how my downpipe started( forgot to pic )
After half an hour of work
Hole for AEM no wield sensor mount
Painted silicone coat
Ready with exhaust wrap
i did the pic i was very bored
HERE ARE SOME PICS (****TIE PHONE PICS) OF THE ENGINE OUT
here are other things I'm putting on the car
Eibach pro damper shocks and struts
neuspeed hi flow discharge, catch can ( getting some mod there), S3 injectors, new spark plugs, and sensor
K&N oil breather for catch can
coolant hoses, coolant, new water pump, turbo exhaust manifold gasket, red seal, assembly lub, oil cooler, new red vacuum hoses and red coil cables cover, cam follower, new south oil turbo feed adapter for oil press gauge pressure sender
4 oil filters (theres never too much oil filters such as cam followers), drive belt, timing belt rollers ad tensor
i cabin air filter and podia oil pressure gauge
new camshafts, sprocket bolt, adjuster bolt and cam cap screws, also gearbox oil seal.
BSH PIPING
and i have been waiting 2 months for these things
new front mount intercooler
and my new babes! Avant Garde M140 12x8.5 r18 ET35
i have been rally busy working, but i finally can concentrate myself in the car ! :laugh:
here i Have some updates, this are the pics of other LEON we finished 2 months ago, and still waiting for other mods, it runs a GTX3071R with 430WHp
love this car!!
there here are some updates of mine! i have been busy in exams so maybe next weekend car is on!opcorn: as i said cams ready, engine block being armed (had some problems with the oil crank gear waiting for new). here i have some pics of the differential, and what i made today afternoon!
i took the homework of polishing every bolt and they finished like this
Differential with ARP bolts
gearbox ready !! :laugh:
I THINK IT LOOKS SICK!
and on weekend i put together the rims with my old wheels
thanks hope likes!
Hey after hard word the car is ready but some details left to correct, i leave you here pics
this is the damage to the old clutch
old brakes
THINHS LEFT TO DO
Oil Catch Can (wield something and plug)
Programming
HOPE YOU LIKE MORE VIDS COMING!
starts
original thread:
--ACTUALLY--
Engine
-FMIC Forge
-S3 up pipe
-EVOMS 3” intake
-Deleted PCV
-NGK Spark plugs
-R8 coils
-Custom catch can
-BSH engine mounts
-HPFP Autotech
-REVO stage 2+
-BSH boost tap
Body
-Eibach Springs pro
-Upgraded sway bars
In the car
-A/F AEM gauge
-Defi Boost Gauge
--COMING SOON--
-K04 turbo
-S3 injectors
-BSH up pipe
-BSH 550Hp FMIC
-Peloquin’s LSD
-Big Brakes
Old DV valve
Water-meth Kit
Old fuel pump
New APR pump
Mounted
BIG BRAKES
BSH PIPING
love this car!!
thanks hope likes!
old brakes
THINHS LEFT TO DO
Programming
