No I'm sure you can't pal.
Right been In my car, there is a brake booster module which it won't let me go into said its not responding so I assume its not there. Also under ABS I could only see where I can activate it under the long coding, do I have to can the code to 0010002 for example?
Do you need any software to go with the cable?
Yeah I got the Software on a cd which came with the cable.
Well when I bought it, it stated there was 5 for sale now none so I have emailed the guy as he lives near me and asked if he has anymore. If so I will post on here.
2009 pal. I heard the don't work on supercopas.
Just changed XDS to 2 so will have to see if it makes much difference.
It's the electronic slip diff. Cupra R and Golf R have it standard set to 2 which is more aggressive so should work more whereas FR default is 0 which is 'slight' so with it set at two it shouldn't understear as much!
Let us know how it is and if you need and hell give us a shout. Was a good spot when scouring the web.
