Car is a 2006 170 FR TDI.
Have been having problems with my dpf light coming on/off for the last two weeks, usually after the light came on I drove on the motorway for around 30mins and it would go off. So went on the motorway and the dpf light light cleared but soon after while still driving on the motorway 2 lights came on (engine and coil, coil flashing first and then engine light stayed on and coil went off) and it went into limp mode. Car has done 111k miles and is due recall work for injectors but wanted dpf issue resolved first
The coil light went out while driving but the ecu light stayed on. After stopping for about 10 minutes, the ecu light went out also.
Now I am trying to figure out what caused this.....also now the car seems to hesitate and seems to be lacking power, its revs up really high and seems like its hesitating....whereas before limp mode it had some good umph at around 2000 rpm but its goes really high around 4000 revs but still struggles...
I did installed some led side lights so I am not sure if this could be a issue or if its just the dpf playing up....no lights on dash at present....
Changed fuel filter today but still the same.....I also took it into a dealer who put it on fault reader and it gave error; P2002 Faulty dpf operation.....he did clear the fault for me and said it maybe worth taking it for a forced regen
I have further driven the car for about 40 miles to see if it regens but I don't think it did...no dpf light has come on since, the revs are sitting at about 750 and did jump to 1000 for a bit.
Anyone have any ideas what this is? The performance was fine before it went into limp mode but now is cr*p. Could it be the dpf now over 90% blocked and the car cannot regen hence the reduced performance? If so what would my best options be? My Mot is also due end of this month
Any ideas guys.
Any ideas guys.
