right ppl keep askin so here it is, this is the quick
guide on n249 bypass for AUQ engine!
1. Remove the vacuum hose between the Fuel Pressure Regulator (FPR) and the underside of the intake manifold.
2. Use 4mm silicone vacuum hose and go direct from newly freed Vac port on intake manifold to top of DV.
3. Put a 6mm BRASS T-piece in the new hose parallel to the FPR and run another length of hose to the FPR vacuum port.
4. Cable Tie the new vac hose wherever it connects to something else.
5. Remove the Vacuum resevoir (Ugly black plastic thing directly over the No.4 cylinder coil pack). The hose going into it simply pulls off.
6. Plug the Vac Resevoir hose with a bolt and clamp it in there with a worm drive or jubilee clip. Do the same with the hose that used to be connected to the top of the Dump valve.
[/IMG]
[/IMG]
thanx to cupra ross for the write up at the top,
