You need:
Screwdrivers
Cutting pliers
Drill/dremel
Glue
Soldering iron (solder,flux)
2x two-poled sockets for brake light
2x 21w/5w brake light bulbs
Wire (5m)
Connectors
Time needed:
I spent about 2,5 hours modifying the sockets, and about 3,5 hours installing them. But I think you can do it a fair bit quicker as I had to figure it out as I went on with it.
Cost:
£5 for two sockets
£5 or maybe less for two bulbs
wires and connectors I had lying around, but I bet you can get them for a few quid.
First you need to take the lamp holder out.
The fog light socket is the lower one, furthest away from the connector.
Using the pliers, cut off some of the supporting plastic, so you're able to bend the earth poles to the side. Also cut off the positive pole a bit away from the socket.
To make the hole big enough for the new socket, I drilled from the backside. First with a 5mm, then 10,15 and 18mm! You can also use a dremel or something similar.
Solder a ~7cm long wire to the positive pole. Put the wire through and insert the new socket. A tip here is to insert the bulb so you can see about what height you need to fasten it at.
Making sure you've got the right heigth, glue it in place from the backside and connect the wire.
Now bend the earth poles back in towards the new socket, and solder them to it. This requires a lot of heat, as the solderability is low! Hard to get it done properly! Make sure you know wich pole are 21 and 5 watts, or make the wires long enough to be interchangeable.
Now do it all again for the second lamp holder.
Insert your new bulbs and you're ready to install!
You need to remove the plastic cover from the hatch, both pieces, center roof one and side of boot to get the wire properly hidden. Didn't take enough photos of this part, But connect to the wire thats for the running lights, should be next to a thicker brown(earth?) cable. If you use connectors and plugs, you can unplug at any time!
Wiring on the hatch
A good idea to check if it all works before you remount the panels!
with brake lights
with fogs
at night
night, side
If you have any comments or questions, please speak!
