Some minor? update :twisted:
Got myself a Liquidgauge:
it was the stand-alone liquid-cube version, Race diagnostics told me it was near impossible to dismantle this, and emails went back and forth, one of them:
[email protected]
To:
[email protected]
Subject: Re: LiquidCube Question
Date: Tue, 20 Mar 2012 20:59:10 +0000
Hi
Tricky but possible, you would need to melt the glue so it is soft but not runny. You would not want the glue on the screen, heat to about 90 deg in an oven and try to pick out the softened glue.
Jim
and then
[email protected]
To:
[email protected]
Date: Wed, 21 Mar 2012 14:55:40 +0000
Hi,
As I said it will not be easy. It is glued in with a combination of heat glue, and silicone glue, I would say that the chances of doing this without damaging the screen are less than 50/50, I would be tempted to cut through the aluminium box to separate the front surface and then heat and cut/prise off.
SWGmotorsport make the inserts so best to go to them and save paying the margin twice.
Jim
50/50 eh? so I though why not ask how much the peice of plastic costs to fit / mount this in the ait vent.... and that went like this:
Hi Mo,
The new fascias arrived today.
Please send £45 via paypal to the address above and I will send one down to you.
Or send £60 via paypal and send your PCB to me and I will fit it for you. Please be aware that as the fascias are hand made every one needs some adjustment to make the pcb fit.
Best regards
Jim
So I thought, hmmm .... like F am I paying £60 for what is just a hollowed out air vent which you can get from the scrappers for around £2-5 quid and set out on a small journey:
Impossible to dismantle eh?:
A bit of Dremel action again (I love this tool)
A bit of glue gun to hold everything in place
And some heavy duty fibre-glassing:
Loads of sanding, a couple of licks of paint:
and wala:
Test fit:
Personally I think mine looks better in the flash than the pre-made one which still has the heater controls on it for some odd reason.
It's very difficult attending to the car these day's with two little babies needing our attention, but I do get a chance, I can showcase some of my skills
