Impeller, Waterpump or Thermostat?
Kris
ESTATE! I'm Getting Old!
Nov 21, 2003
808
North Essex
Visit site
I'm haveing my water pump and cambelt changed on thursday next week, and i'm going to hospital on that day so it will be another two weeks before I can drive my car again.
(It's going too feal like a rocket when i finally drive it, compared to the 1.5 td corsa i'm driving now!)
aboutime11
Same problem
Hi did you manage to find out what the problem was?? i have a leon cupra 20vt on a 52 plate and when i first start it up within a minute the temp shoots up to half way then stays there.After about 5 mins if i stick my boot down a bit the temp will rise close to the red light coming on but if i pull over and let it idle the temp drops back to normal???All the while its just ticking over its fine but when it starts to heat up i lose power.
LEE69
Stage 2 Revo'd
Dec 10, 2004
21,262
74
C\UK\Devon\Torquay
Waterpump gets my vote.
Seems to be coming around again these failures.
I guess the fans are working ok?
bendohhh
172
Stockton
Another vote here for the water pump, mine had the same symptoms. Be prepared to pay for a cambelt change at the same time, may as well whilst you're in there.
