http://www.youtube.com/watch?v=aGbiPeQ6k7k&playnext=1&list=PL1B19A4C6B4441880
The Evoms gives the treble and the Milltek the mid and the bass. Love it![]()
Good Good.. Ive got The Miltek installed
You also have to consider the position of the MAF in the intake pipe for these figres. A dbilas for example sits off centre and as a result shows low figures as the mass of air (centre of the air feed) doesnt pass the sensor.
What you can't dispute however is that the fastest 2.0T cars mostly run EVOMS intake. That may be because the EVOMS was available sooner and more money spent on those cars, or it could be that those cars also had secondary air feeds etc etc.
As an example, mine ran to almost 116mph teminal speed on the 1/4 mile with an Evoms and S2+. Closest Leon Cupra I have seen to that was RobH at 114 (I think) and I am sure he runs an Evoms too.
I'd be careful of the neuspeeds pipework that mounts to the engine block, looks exactly like the BSH Truseal and H8T WP managed to break his mounting lug off.
I always thought that the Fuel Pump was one of the problem factors when you upgrade the air intake?
what is the mounting lug used for, does it hold anything else. I guess the evoms and ITG do not use this lug
i was thinking the same Rob but more along the lines CDA BMC enclosed filter with air feed. would make it a proper CAI then i guess
lee
will that be cheap to make and can you make more than one
Lee
Fuel pump is only a factor when going to stage 2+ as stage 2+ requests more fuel/pressure than the oem pump can deliver. I hope I'm right lol
And as K1Shane pointed out, I'm running a p-flo filter and works fine on my car, I keep up with alot of higher powered cars and the filter doesn't seem to hinder my cars performance in anywayRevo said it's one of the top filters for the 2.0TFSI but at half the cost of most others
