If your Traction control or ESP warning light comes on after about 10 minutes of driving and won't go off until you turn the engine off, then there is a Strong possibility that your "Load Signal" cable has snapped.
Unfortunately due to a slight Design flaw in the wiring loom, it seems to be a common fault for this wire to snap, so I have taken the liberty of creating a bit of a guide to fixing the fault:
The relative Connector plug is held onto the front of the gearbox by a bracket and can be seen by looking up from underneath the car with the under tray removed. It is located about 3 inches back from the bumper towards the nearside of the car just above the longer radiator hose. It is a Two wire connector block in which my case, BOTH wires had broken off.
Here you can see the connector in its "home" position with no wires attached on one side.
Here's the culprit! Two bare un-connected wires!
As you can see by the state of the connector the wires had quite literally clean snapped off!
I found myself One blue and white and a light blue length of wire Just enough to extend the loom so that lateral movement would not cause the problem again. I removed the wiring plug and used 4x standard red butt connectors to join the loom extension making sure the connect wires were connected to each other.
I then re-loomed the wires together using black electrical tape and used a bit of orange silicone rubber to stop the metal bracket chafing on the new loom. Enough slack was left on the side that had broken for any lateral movement not to cause the same problem.
Hopefully this rough guide to how I fixed mine with the photos will help some of you guys out in the future
Would like to give a big thank you to everyone who has helped out in this matter!
Cheers guys
Cheers guys
