jdj-type-r
im looking into gettin the eibach front and rear arb kit 25mm. i have a supersprint exhaust system and am planning to lower the car 30mm+ will this cause any problems with rubbing/knocking etc?
Which Leon is this on?im looking into gettin the eibach front and rear arb kit 25mm. i have a supersprint exhaust system and am planning to lower the car 30mm+ will this cause any problems with rubbing/knocking etc?
i fitted h&r front and rear arb to my tdi and wow what a difference it made. well worth it
If it's Cupra fitment it'll go over, if it's Cupra R fitment it'll go under but need to be attached to the shock. And I think you might need the Cupra R wishbones and hubs like DPJ had to be able to fit a Cupra R ARB as well.
I take your point Danny, but the extensions you mention to the damper bottoms are only there to act as lever arms to transfer the twisting forces to and from the bar that's strapped to the axle beam. In the case of my proposed cheapo simpleo welded alternative then these forces would be transferred by the trailing arms, as the already do into the stock beam!
As a side question, does anyone know if the Whiteline or Eibach RARB will fit with the OE LCR Cat-Back exhaust?
I've got the R32 front one in the loft waiting for the car to stop breaking down and costing money long enough to be able to afford to fit it. I was going to go with the Whiteline rear one too, it's almost £100 cheaper than the likes of Neuspeed and is adjustable so I reckoned on it's stiffest setting it would be near enough as good as the Neuspeed to make the extra £100 not worth going for.
